ReWiring Cruise Control....Anyone?????
Old Apr 5, 2005
Pharoh's Avatar
Bobaganoosh!
Exclamation ReWiring Cruise Control....Anyone?????
Ok....quite some time ago my friend and I swapped out my steering wheel for the EP3 wheel.
trouble is....we realized that the wiring isn't all compatible. The SRS and horn are fine...(horn is just a ground anyway), it's the cruise that doesn't match up.
so he just decided to cut the wires from the OEM cable reel and splice them into the cruise wires from the wheel This obviously didn't work.
question is: When putting back on the OEM wheel should it be possible to solder the wires back together and expect the cruise to work?? I think I can save myself a lot of money by doing this as opposed to buying a new Cable Reel for over $200.
Old Apr 5, 2005
skipbarber's Avatar
yes, of course it will work when you put the oem wheel back on. I don't have an EX, but how hard is it to take the cruise buttons off the EX wheel and swap it with the EP3 wheel? that way it would be plug and play...OR get the pinouts for the EX unit and match them up with the EP3 unit.
Old Apr 5, 2005
Pharoh's Avatar
Bobaganoosh!
yah, I want to put my OEM wheel back on though. I sold the EP3 wheel and need to get it off the car...but I'm trying to get my cruise to work at the same time.
I'm hoping that just soldering the wires that were cut will do the trick
Old Apr 5, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Just soldering should work fine.
Old Apr 5, 2005
Pharoh's Avatar
Bobaganoosh!
other thing is this....
the horn stopped working....I'm wondering if I might have blown the relay under the hood. I'm told that the horn would have worked ordinarily after the swap so I'm guessing something blew.
Old Apr 5, 2005
TeLLy's Avatar
I'm guessing the relay blew or maybe the brown horn plug wire isn't connected to a solid spot that grounds when the button is pushed.
Old Apr 5, 2005
skipbarber's Avatar
there is no way the relay blew for the HORN, there is such a low amount of current going through it, it takes alot to blow a relay. I bet you it's the horn fuse, or it simply came undone in the wheel.
Old Apr 8, 2005
Automated1's Avatar
Automated1 is an unknown quantity at this point
when u cut the wires in the harness did u disconnect the wires from the battery? If not i would start checking ur fuses...
Old Apr 8, 2005
Pharoh's Avatar
Bobaganoosh!
yeah battery was disconnected before we did anything.
h4ldol
Apr 24, 2017 08:16 PM
carid
Sep 28, 2015 10:13 AM
jerry38
Sep 20, 2015 08:38 AM
EM2661
Sep 11, 2015 06:01 PM
Klame9420
Sep 7, 2015 10:03 PM
