neuspeed sports cracking noise?
Old Apr 1, 2005
mackin's Avatar
mackin is an unknown quantity at this point
for anyone who installed neuspeed sports springs with stock struts hear any cracking/knocking sounds?
I just had my neuspeed sports, spc camber kit, and rear lower tie bar installed today on a 2004 coupe ex, and occassionally i hear cracking noise in the rear...can someone tell me what's goin on?
thnx
Old Apr 2, 2005
Phil_Qc's Avatar
Phil_Qc is an unknown quantity at this point
Be shure that the springs are seat properly.
Also, you should lube the bearing/bushing of
the rear camber kit.
In my opinion, if it's a creaking sound, it's the
camber kit. But if it's a coil binding sound, your
springs are not seat properly. In the DIY, there
is a section about preloading the rear suspension
before you tight the shock mount bolt...
http://www.7thgencivic.com/forums/sh...ght=spring+diy
Hope that help... I have the same setup w/out any noise.
Philippe
Old Apr 2, 2005
mackin's Avatar
alright thnx
i got it done at a shop..so i suppos they did those?
Old Apr 2, 2005
skipbarber's Avatar
cracking noise? like plastic cracking? that could be your dust cover. I didnt have that happen to me with my neuspeed sport springs, but my tein SS were pinching my rear dust covers and caused a really loud clicking/cracking noise when the rear would jounce.
Old Apr 3, 2005
mackin's Avatar
mm..its' not like plastic cracking..i dont' know how to describe it, but i'll get my friend to hear it and see if he can describe the sound.
btw, does it matter if the spring is upside down? cus i saw the lettering in the rear are upside down..like "made in germany" upside down..would that be the problem?
or actually, could it be the lower rear tie bar?
Old Apr 3, 2005
K20EQUIPPED's Avatar
K20EQUIPPED is an unknown quantity at this point
upside down is fine...I have the same noise for the first time in 2 yrs....you have to index the housing.
Old Apr 3, 2005
nindoo's Avatar
Why is my vagina bleeding?
What is indexing the housing?
Old Apr 3, 2005
skipbarber's Avatar
drawing a line down the middle so everything lines up.
Old Apr 4, 2005
scatman's Avatar
Still in the game...
thnx
its just the way the spring is seated. i have the same thing happening once and a while.....just give it time.
Old Apr 9, 2005
mackin's Avatar
hey everyone, i was just wondering if it's possible that the dead coils are touching and making a noise when i go over bumps/bumpy roads.?
oh and what happends if you tighten the bolts too much, like over the torque specs?
Old Apr 9, 2005
skipbarber's Avatar
yes, very common, wrap them in tubing,
Old Apr 10, 2005
RIC3BOY's Avatar
RIC3BOY is an unknown quantity at this point
I'm experiencing the same problems. I have Neuspeed Sports with stock struts/shocks. Everytime I turn the wheel at low speeds I hear some sort of popping or cracking. The last time that happened to me was when the front struts were blown due to the front struts being faulty (they were later replaced under warranty).
I plan to change my whole suspension to Omni coilovers. If you're still under warranty, replace your springs to the original/stock ones and take them back to Honda (since they won't do it under warranty now because you changed your springs).
Good luck.
15EXCoupe
Jul 30, 2015 12:59 PM
krazykoncepts
Jul 14, 2015 01:55 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
stvpagn
Jul 9, 2015 09:59 PM
