D16y8 Manifold fitment
Boosted Auto Sedan Project In Progress
Ok now i know that it is possible to swap in this part but after looking around to see how it is done no one has posted that up. so i was wondering if someone could tell me how to do it is it basically drilling in new holes or what. plus if you can tell me all the parts i would need to make it work? thanx yo all and before you flame me for posting this can you at least post up a link that says how to make it work maybe i missed it.
it will fit with modification and im trying to figure out what that modification is! but all i know is that the d16y8 manifold is like the type R manifold for the d series motors
the skunk 2 manifold will not fit it would hit the fire wall, because of the longer straight runners. I am interested in y8 mani fitment also.
I have modded one to fit but its not installed yet there are two holes to hog out on the flange and the ports need to be opened up a lil bit. You can use the factory injector flange as a template. I welded a flange on mine to use the d17 TB because its a lil bigger.
if i get a ported d16y8 manifold and new fuel rail and injectors thats good right then i just got to drill out those to holes. and for the throttle body i can just use a bigger d16 one that will fit right up
Well as far as wiring i think you may have to wire up the old stye injector plugs, not sure though. I already have mine wired for RCs. Also the idle control unit is different. You will probably need a d16 TB and idle control. This is the other reason why I welded our style flange on, no frigging with the Idle control. other than that you will need to either tap a spot on the manifold for the map sensor or use one of the 3/8 ports and rig up a vacuum line to it.
i bet it would work good for na apps too. I ran it without the charge pipe connected and it actually pulled a lil more in the top end. with boost it works awesome though. Def worth the work. If anyone needs a flange welded on a y8 manifold let me know. I have made up cnc machined flanges that accept factory o-ring gasket. Makes the swap easier. I cant give them away but ill only charge what I need to get all the stuff and for the shipping.
Yeah I could do that I suppose. Id need a manifold and the fuel rail/injectors for it I can port it out/ gasket match, change the flange, and all the other stuff for like $200 + shipping. You guys will just hafta wire up some old style injector clips and cut up a cai to fit. I can adapt that rail to take our style fuel line and Ill make a block off plate for the pressure regulator. If you wanna convert to a return system you can take off the plate and add the aem regulator after. so for like 300 bucks you could have a real manifold depending on the price you get for the parts.
jdh022764
18
Nov 3, 2015 06:44 AM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
Mannimarco
Sep 7, 2015 10:01 PM
