D16y8 Manifold fitment
Old Apr 1, 2005
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
Ok now i know that it is possible to swap in this part but after looking around to see how it is done no one has posted that up. so i was wondering if someone could tell me how to do it is it basically drilling in new holes or what. plus if you can tell me all the parts i would need to make it work? thanx yo all and before you flame me for posting this can you at least post up a link that says how to make it work maybe i missed it.
Old Apr 1, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
caorndoff (spelling?) has swapped the d16y8 mani ... he's selling his kit too, I believe ...
get the skunk2 d16y8 manifold and swap that!
Old Apr 1, 2005
02sleeper's Avatar
maybe he should put up a DIY
Old Apr 1, 2005
exturbo6's Avatar
mmm so i could invest in a skunk2 mani for a d16y8 and it will fit with no prob?
Old Apr 1, 2005
02sleeper's Avatar
it will fit with modification and im trying to figure out what that modification is! but all i know is that the d16y8 manifold is like the type R manifold for the d series motors
Old Apr 1, 2005
djmota's Avatar
the skunk 2 manifold will not fit it would hit the fire wall, because of the longer straight runners. I am interested in y8 mani fitment also.
Old Apr 1, 2005
02sleeper's Avatar
yeah i remember a post showing the size difference and it was to long but i bet a ported regular one would make just as much power
Old Apr 1, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I have modded one to fit but its not installed yet there are two holes to hog out on the flange and the ports need to be opened up a lil bit. You can use the factory injector flange as a template. I welded a flange on mine to use the d17 TB because its a lil bigger.
Old Apr 1, 2005
02fpcivic's Avatar
yeah it seems like a killer setup I give props to the guy who did it first. I sold my custom manifold because I needed the dough. This setup saves me some money for sure hehe
Old Apr 1, 2005
02sleeper's Avatar
thanks dude but what do i need in addition to the manifold and basically your saying that all i need to do is drill some new holes and thats it
Old Apr 1, 2005
02sleeper's Avatar
if i get a ported d16y8 manifold and new fuel rail and injectors thats good right then i just got to drill out those to holes. and for the throttle body i can just use a bigger d16 one that will fit right up
Old Apr 1, 2005
02sleeper's Avatar
i read on another thread that there is complex wireing involved is there i thought it was just fuel lines and the throttle cable
Old Apr 1, 2005
02fpcivic's Avatar
Well as far as wiring i think you may have to wire up the old stye injector plugs, not sure though. I already have mine wired for RCs. Also the idle control unit is different. You will probably need a d16 TB and idle control. This is the other reason why I welded our style flange on, no frigging with the Idle control. other than that you will need to either tap a spot on the manifold for the map sensor or use one of the 3/8 ports and rig up a vacuum line to it.
Old Apr 1, 2005
02sleeper's Avatar
gotcha i guess i have to go back to my high scool garage and use some heavy tools but in all i think i can get it done
Old Apr 1, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
It is an awesome swap...If I was going with a boosted set-up I would definately do it...good luck man!!
Old Apr 1, 2005
02sleeper's Avatar
definitly a boost setup and yes i hear good things i just wish i had a digi cam to post pics of it when its done
Old May 19, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
anyone have anymore info on this yet ? is it really woth it i dont think it would give you more than 10hp especially since the ports are smaller unless its ported
Old May 19, 2005
mr_fobster's Avatar
so is that setup mainly for boost? or wat? im thinking about it right now too but im still confused about some things.
Old May 19, 2005
02fpcivic's Avatar
i bet it would work good for na apps too. I ran it without the charge pipe connected and it actually pulled a lil more in the top end. with boost it works awesome though. Def worth the work. If anyone needs a flange welded on a y8 manifold let me know. I have made up cnc machined flanges that accept factory o-ring gasket. Makes the swap easier. I cant give them away but ill only charge what I need to get all the stuff and for the shipping.
Old May 19, 2005
2K1Civic17"Gabe's Avatar
So with this stuff you sell, it would be a direct swap basically than, no modifying???
if so, pimp!
Old May 20, 2005
02fpcivic's Avatar
Yeah I could do that I suppose. Id need a manifold and the fuel rail/injectors for it I can port it out/ gasket match, change the flange, and all the other stuff for like $200 + shipping. You guys will just hafta wire up some old style injector clips and cut up a cai to fit. I can adapt that rail to take our style fuel line and Ill make a block off plate for the pressure regulator. If you wanna convert to a return system you can take off the plate and add the aem regulator after. so for like 300 bucks you could have a real manifold depending on the price you get for the parts.
Old May 20, 2005
02fpcivic's Avatar
you will also be able to keep your cruize control
SammySC
121
Apr 7, 2017 07:43 PM
jdh022764
18
Nov 3, 2015 06:44 AM
winanthony94
Sep 25, 2015 09:05 AM
chiquita.banana
Sep 24, 2015 09:42 AM
Mannimarco
Sep 7, 2015 10:01 PM
