installed cai now check engine light is on
Old Jan 7, 2002
Coopex's Avatar
Coopex is an unknown quantity at this point
I finally broke down and started buying parts for my car. but I ran into a little problem I installed the AEM cai this weekend and when i went to start it up the check engine light came on and it idles a little higher than normal. I dont know what i did wrong. but it really starting to **** me off. Well if any of you have run into this leave a message after this or email me @ westsyd17@aol.com
Old Jan 7, 2002
silentbutviolent's Avatar
silentbutviolent is an unknown quantity at this point
how many miles are on the car
Old Jan 8, 2002
fuse's Avatar
fuse is an unknown quantity at this point
I just installed my AEM cai a couple days ago too and my car idles higher then normal. I'm hoping its just cause my ecu hasnt gotten used to the mass amounts of air coming from the intake.
As far as the check engine light did you reattach the o2 sensor?
Old Jan 8, 2002
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Check and make sure the o2 sensor is place on the right place.
Check all connections and hoses.
Next, disconnect your possitive terminal of the battery for about
3 minutes the light sure go out by then.
About the idle being running high is because of the change of air intake, this is quite normal, your fuel comsumtion will go up as well.
Is you car an automatic?
After doing all the moods to your engine is a good idea to have your CPU tuned with the changes of your car.
You may have to find a good shop other than the dealer to do so.
Is no big deal, all they have to have is a computer reader that will fit your car and change a few settings.
If you are going to modify your car you must get the service manual for this car, is a good thing to have.
Good luck
Supermex
Old Jan 8, 2002
spyder597's Avatar
spyder597 is an unknown quantity at this point
Disconnect your negative cable on your battery not the positive, I had the same problem when I did mine last summer, it will all turn out fine
Old Jan 8, 2002
Coopex's Avatar
thanks for the response to answer all the questions its a manual yes I plugged all the hoses and and sensors back in. Only thing I couldnt get the clamp to go on the vacume hose on the engine I dont think that should pose a problem. I am getting some racing harts in a few days and will have to send in a pic
thanks
Old Jan 20, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
Mine Reaches 4000 RPM Idling speed when I just install my AEM CAI with Bypass valve. When I was test driving it for some strange reason my idling reaches that speed but it never happen again
Old Jan 20, 2002
emmagatorone's Avatar
emmagatorone is an unknown quantity at this point
When you start putting engine mods on your car ie: CAI your car will idle a little differently for a little while. What's happening is that your computer is adjusting all the settings for your idle/a/f mixture etc.... After you drive it for a little bit, it will go back to normal. As far as the check engine light, yeah, what he said! It could be the milage on your car in which you just reset it (that is if everything is hooked up properly on the CAI and there is really no reason for it to be on) following the D.I.Y!!
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
