K20A compression
K20A compression
When I do a compression test on a K20A (Type R) what are the figures that I should look for ???????
example what is the average number across all cylinders and if it fluctuates too low (what is too low)
I wanna determine if the piston rings are good......
DONT PANIC
test them all. if the numbers are not within 10 psi of eachother, then you have a problem. It is very rare that you will have a motor that all the cylinders have the same compression, but have a blown motor.
Just run the test, and if the compression in all the cylinders is within 10 psi, then the motor is most likely fine.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
