K20A compression
Old Mar 20, 2005
kezay's Avatar
kezay is an unknown quantity at this point
K20A compression
When I do a compression test on a K20A (Type R) what are the figures that I should look for ???????
example what is the average number across all cylinders and if it fluctuates too low (what is too low)
I wanna determine if the piston rings are good......
Old Mar 20, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
this forum probably isn't the best place to check ;P
try k20a.org
Old Mar 20, 2005
kezay's Avatar
Just though that there are so many member with K20 in the civics that at least someone would of known what the numbers should be....
Old Mar 20, 2005
turboengnr's Avatar
DONT PANIC
test them all. if the numbers are not within 10 psi of eachother, then you have a problem. It is very rare that you will have a motor that all the cylinders have the same compression, but have a blown motor.
Just run the test, and if the compression in all the cylinders is within 10 psi, then the motor is most likely fine.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
C-Hamm
Sep 28, 2015 10:31 PM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
