Missing link or e-manage
Ok people keep confusing me, so I plan on using e-manage with my turbo setup does this mean I still need to use the missing link or not? I want to run 9 psi when I race so could someone clarify this for me
Now I've done my research but what is a voltage clamp and where can I get one and where does it go to. Sorry about this but I had no idea that we need to use a voltage clamp with the emanage when we don't use a missing link.
Originally Posted by dinglenuts
does the missing link let you safely run 8 psi ish with proper tuning etc? or is it more like a band aid.
a ML is just a check valve. It keeps the stock map sensor from seeing boost. Our cars work off of vaccum, if the map sensor senses boost, then it will go apeshit and will kick into limp mode.
Boosting Daily
Originally Posted by Titleist71
lol..it's not a clamp like you think...it's a programing clamp within the Emanage to moderate voltage being sent to the ecu. Dezod....DR.Dezod I mean can explain better.....
7thgen Power Maker
Originally Posted by tfnaaf
If ya could DR.Dezod can you explain a little better
yeah, they do the same thing, but emanage probably works for higher boost. not too sure, but Ive heard about the 10psi thing with the ml a few times before. I like TSIs, it is sort of like a vtec kicking in......on a lx, lol. But that could be what broke my tranny mount. The tranny's off center by like an inch with rubber all around it cracked in about 4 spots, rubber hanging out, its sad.
I have the tsi black box and a safc2. I am getting a high voltage code in the car whenever i hit boost. what could be the problem? the "black box" is a ml right? was it not installed correctly? would love some help
Originally Posted by Mex
i'm curious, if you're using the e-manage, does the pressure sensor substitute the missing link? where does it get the pressure reading from?
anybody??
Originally Posted by dezod
To put it quite simply it limits the voltage the ECU sees over and above what you set it at. For example, if you clamp it @ 3V, the ECU nevers sees anymore voltage than 3V, which means the car never sees more than 60% throttle, hence you can program custom fuel curves from that point on. Remember you ALSO have to accomodate for normal driving because your not allowing the ECU to use it's already pre-programmed WOT or higher levels of throttle fuel maps.
Originally Posted by BlackFire
How about clamp it at what the ECU sees at WOT?? Then program the fuel curves as well... how much volt does the ECU sees at Wide Open Throttle from the MAP sensor when there is no boost (when it stills being an N/A engine)??
as i recall its 2.95 volts
Because, as Dezod said: 3.0V is for 60% throttle, and 2.95V is at Wide Open?
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
