Missing link or e-manage
Old Mar 16, 2005
cbaer543's Avatar
cbaer543 is an unknown quantity at this point
Ok people keep confusing me, so I plan on using e-manage with my turbo setup does this mean I still need to use the missing link or not? I want to run 9 psi when I race so could someone clarify this for me
Old Mar 16, 2005
dezod's Avatar
7thgen Power Maker
I have used both. You can use either or.
ML or the E-Manage voltage clamp
or
the E-manage & not the voltage clamp w/ the ML
Old Mar 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
if ur setup require a emanage, then u don't need a ML.
if you are not running a emanage, then save the $$$ and just buy a ML.
Old Mar 16, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Now I've done my research but what is a voltage clamp and where can I get one and where does it go to. Sorry about this but I had no idea that we need to use a voltage clamp with the emanage when we don't use a missing link.
Old Mar 16, 2005
Titleist71's Avatar
lol..it's not a clamp like you think...it's a programing clamp within the Emanage to moderate voltage being sent to the ecu. Dezod....DR.Dezod I mean can explain better.....
Old Mar 16, 2005
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
does the missing link let you safely run 8 psi ish with proper tuning etc? or is it more like a band aid.
Old Mar 16, 2005
civic01vtec's Avatar
a ML is just a check valve. It keeps the stock map sensor from seeing boost. Our cars work off of vaccum, if the map sensor senses boost, then it will go apeshit and will kick into limp mode.
Old Mar 16, 2005
Titleist71's Avatar
w3Rd...
Old Mar 16, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
I've heard problems with the synapse ML over 10psi. I used mine up to 9lbs when i sold it with no problems what so ever. I miss it too. I'm running TSI's "Black box" ML. The synapse had a much much better vac-boost transition. The black box makes it feel like i-vtec engaging on a k! Can't be good on the engine for daily driving (power spikes)
Old May 17, 2005
tfnaaf's Avatar
BLDNPSI Mod
If ya could DR.Dezod can you explain a little better
Old May 17, 2005
dezod's Avatar
7thgen Power Maker
To put it quite simply it limits the voltage the ECU sees over and above what you set it at. For example, if you clamp it @ 3V, the ECU nevers sees anymore voltage than 3V, which means the car never sees more than 60% throttle, hence you can program custom fuel curves from that point on. Remember you ALSO have to accomodate for normal driving because your not allowing the ECU to use it's already pre-programmed WOT or higher levels of throttle fuel maps.
Old May 17, 2005
tfnaaf's Avatar
BLDNPSI Mod
So in your opinion what way is better/easier?
Old May 17, 2005
Michalo187's Avatar
Abortion Survivor
my tuner said just to get the ml just for 8 pounds
Old May 18, 2005
dezod's Avatar
7thgen Power Maker
Personal preference.
Old May 18, 2005
2K1Civic17"Gabe's Avatar
yeah, they do the same thing, but emanage probably works for higher boost. not too sure, but Ive heard about the 10psi thing with the ml a few times before. I like TSIs, it is sort of like a vtec kicking in......on a lx, lol. But that could be what broke my tranny mount. The tranny's off center by like an inch with rubber all around it cracked in about 4 spots, rubber hanging out, its sad.
Old May 18, 2005
dezod's Avatar
7thgen Power Maker
I know of no limitations with the ML.
Old Jun 13, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
who is running a missing link successfully? and for how long?
Old Jun 13, 2005
Jeromie's Avatar
Jeromie is an unknown quantity at this point
I have the tsi black box and a safc2. I am getting a high voltage code in the car whenever i hit boost. what could be the problem? the "black box" is a ml right? was it not installed correctly? would love some help
Old Jun 13, 2005
Michalo187's Avatar
Abortion Survivor
I have 02 sensor high voltage and all cyclinders missing i have emanage slightly tuned and synapse missing link
Old Jun 13, 2005
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i'm curious, if you're using the e-manage, does the pressure sensor substitute the missing link? where does it get the pressure reading from?
Old Jun 13, 2005
bump
Old Jul 15, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
I have the same question??
anybody??
Old Jul 15, 2005
BlackFire's Avatar
How about clamp it at what the ECU sees at WOT?? Then program the fuel curves as well... how much volt does the ECU sees at Wide Open Throttle from the MAP sensor when there is no boost (when it stills being an N/A engine)??
Old Jul 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
as i recall its 2.95 volts
Old Jul 17, 2005
BlackFire's Avatar
So, the more volts the MAP sends to the ECU means it means less pressure, and the less volt means more pressure??
Because, as Dezod said: 3.0V is for 60% throttle, and 2.95V is at Wide Open?
juicetayne
Sep 30, 2015 11:02 AM
rovafa2002
Sep 28, 2015 06:57 PM
Bruce2
Sep 27, 2015 08:45 PM
