exhaust temp
Old Mar 11, 2005
civicdragster02's Avatar
civicdragster02 is an unknown quantity at this point
Question exhaust temp
I was going to get a pyrometer does anybody know how hot a civic
runs stock and what are the criticle temps that I should stay away from
Thanks
Old Mar 24, 2005
03civicdx's Avatar
03civicdx is an unknown quantity at this point
why are you gonna get a pyrometer? we dont need them for civics those are made for diesels. i cant think of anything that would make your engine run so hot that your Coolant Temp sensor wouldnt pick it up. So basically it doesnt make sense to do it
Old Mar 24, 2005
juzthewy's Avatar
juzthewy will become famous soon enoughjuzthewy will become famous soon enough
lol @ diesel
Old Mar 24, 2005
tfnaaf's Avatar
BLDNPSI Mod
ACTUALLY, it makes great sense if its modded with a turbo/n2o. But im unsure of what a stock reading would be
Old Mar 24, 2005
c kim's Avatar
c kim is an unknown quantity at this point
If you're boosted then it's a good idea to get but if you're not then it's just stupid and kinda ricey. EGT's act as an a/f meter. The higher the exhaust temp. the leaner your engine is running.
In my opinion, I think they're better than the regular a/f ratio meters are used to seeing. It's more helpful b/c it gives you exact temperatures instead of just telling you if you're running too rich or too lean.
Old Mar 24, 2005
OKAY OKAY!!!! I'M stupid (but I'm still getting a pyrometer)
Old Mar 24, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Not completely.
If an engine is running too rich, it will also run high EGT, as well as if your timing is retarded.
Old Mar 24, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
I have the Autometer Cobalt Pyrometer, and i'm ride's running rich right now and I installed the pyrometer about 24" away, ideal location is about or with in 6"-12" away from the exhaust manifold, mine reads around 700-800F, so I just add 3 more hundreds to compensate with the distance then that should be the estimated exhaust temp... overheating/melting melting temp should be around 1600F and above
BigG422
Sep 9, 2015 10:59 PM
alinaray
18
Aug 24, 2015 01:04 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
Kcpowerhouse
Aug 1, 2015 06:55 AM
Dani1993
Jul 24, 2015 09:02 AM
