Is it Possiable
Old Mar 11, 2005
blue2k2ex's Avatar
blue2k2ex will become famous soon enoughblue2k2ex will become famous soon enough
Is it Possiable
Is it possiable to get the headlights out to clear them without removing the front bumper?
Old Mar 11, 2005
dirtySAMURAI's Avatar
I log in from time to time
sure. just rip dem bishes out. you'll have to buy new headlights afterwards though.
Old Mar 11, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
nope. just take the bumper off. its easy. If you dont think you have the ability to, you shouldnt trust yourself heating up and opening headlights.
Old Mar 11, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
i dont know if its possiable, but i DO know that it is possible, yes.
you do have to partially remove it though- at least the top section.
just remove the black plastic "screws" just above the upper grille (under hood), and the screws (one on each side) in the wheel well holding the front bumper on. you have to pull outward (away from the car) on the bumper over by where u take the wheel well screws out.. then once thats loose- you can pry around he headlights, and at the upper grille. it will be akward to get the lights off, you need a wrench extension, and lots of patience. i was never able to put back the bottom screws on my headlights though. maybe better off taking the bumper all off. its only like 4 more screws anyway.
Old Mar 11, 2005
taking the front bumper off is cake... after doing it a few times... its really not that hard... go for it!!
Old Mar 11, 2005
suthrninca's Avatar
suthrninca is an unknown quantity at this point
It's easy. I've taken mine off 5 or 6 times, now I can do it in less than 5 min.
Old Mar 11, 2005
i have like 10 of those black push clip things that came from my front bumper. whenever i take my bumper off i always have at least 2 more clips. then honda replaces them for me
Old Mar 11, 2005
2k1civic.com O. G.
You can actlaly take the headlights off without completely removing the bumper. THe catch is you have to do one side at a time and have a nice long 10 inch extension for your ratchet to get the bottom bolt of the headlight.
Just remove the top plastic flat head clips. Remove the wheel well screw and pull the bumper off on that side only. Let the bumper hang just enough to get the bottom headlight bolt off.
Old Mar 11, 2005
Michalo187's Avatar
Abortion Survivor
Just remove it if you want the job done right
Old Mar 11, 2005
AlienX's Avatar
AlienX will become famous soon enough
it makes it 10 times easier to when you remove the bumper.
And it really is a 3-5min job to remove it.
Old Mar 11, 2005
JCiv03's Avatar
removing the bumper is not too hard. Once you know what to do, it should only take 10 mins
Old Mar 11, 2005
10 minutes? it takes me less than 1 minute.
Old Mar 12, 2005
exclusive_vtec's Avatar
no u cant clear em unless u take off ur front bumper
Old Mar 12, 2005
ncirom2003's Avatar
if you know how to turn a wrench you have no excuse to mickey mouse the job. just take off the bumper
Old Mar 12, 2005
MiamiUgen7's Avatar
Not to my knowledge. When I did mine, there were bolts hidden behind the bumper connecting it to the fender.
Old Mar 12, 2005
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
id recommend that you disconnect you negative battery terminal too just incase you hit the SRS sensor with the wrench or something...
Old Mar 12, 2005
blue2k2ex's Avatar
The reason I ask is because my front bumper isn't stock and it's more of a pain in the *** to take off then the stock. Thinking of selling my body kit and putting my stock bumpers back on for this reason it makes everything more difficult.. Thanks guys
Old Mar 12, 2005
Nodnero's Avatar
I'll keep it sweet and simple: NO.
Use the DIY thread, its easy as fjck to take the bumper off. Plus, Im not sure if anybody else has mentioned, but you dont have to put all the bolts back in thus increased weight savings!!! Weight reduction kit stage 0.03!!!
Old Mar 12, 2005
PlasmaGT's Avatar
My Baby Daddy
PlasmaGT is on a distinguished road
Simple answer - Yes you can
Old Mar 12, 2005
Hawk's Avatar
You boost, I-VTEC
all you need is one tool to remove headlights
or if your less patient this will work just fine.
Old Mar 12, 2005
ImPulse's Avatar
possiable = no
possible = yes with,
michaelcal121
Oct 13, 2012 09:45 AM
K20A_Wanabe
Sep 8, 2007 12:12 AM
zzeroz
Apr 5, 2006 08:40 PM
cwick187
Bolt-on Engine Performance
Feb 19, 2006 12:47 PM
