Headlight alignment on 2004+?
Old Mar 10, 2005
Redviking's Avatar
Redviking is on a distinguished road
Due to a small accident my front passenger headlight was replaced... but the headlight is not pointing correctly (too low and too much to the right).
How do I adjust that? (I don't want to return to the dealer for that...). Where are the alignment bolts on this car? I think there is one just in front of the battery (I will removed it to confirm), but where is (are) the other(s)?
Thanks!
Old Mar 10, 2005
Bires's Avatar
Bires is an unknown quantity at this point
If I were in your shoes, I would take it back to the body shop to do the alignment, because they may not have lined the housing up with the fender.
Old Mar 11, 2005
streetglower's Avatar
that wouldnt be the problem. When you buy new headlights, they dont come aimed. They have to be aimed once they get put on the car. Most likely they didnt do that.
There are 2 screws behind the headlight for the adjustment, but I would take it to the bodyshop since they should have done it.
Old Mar 11, 2005
Redviking's Avatar
Ok then, seems like I'll go see them (again).
But for my information, where is the second ajustment bolt... maybe I am blind but I cannot locate it! I just saw one, when I last checked.
Old Mar 11, 2005
Redviking's Avatar
I finally found a DIY! Hope it is the same for 2004+... I'll try this week-end!
http://www.7thgencivic.com/forums/sh...adjustment+56k
Old Mar 11, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Its not, already tried it. Just take it to the body shop. I gotta get up there also.
Old Mar 12, 2005
Redviking's Avatar
You are right, they are different. But, I found the bolt to adjust Up/Down. My headlight looks okay now, at least my left and right beams are at the same height. Still looking for the Left/right adjustment bolt...
Old Mar 12, 2005
Civic04's Avatar
Civic04 is an unknown quantity at this point
Might not have it that is the case with alot of new cars. dont know why they just got cheap on us.
Old Mar 12, 2005
TemjinX2's Avatar
I dont think there is a left and right bolt for the 04+ headlights. I think your going to have to go the dealer for the left and right.
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
