LOW Beam/ HIgh beam
Old Mar 10, 2005
T's Avatar
T
T is an unknown quantity at this point
LOW Beam/ HIgh beam
Do the high beam and low beam share the same fuse???
and when high beam is switched on, does it draw more power than normal low beam?
Old Mar 10, 2005
wonderz's Avatar
wonderz is on a distinguished road
high beam and low beam from the same side share the same fuse. basically you have a fuse for the left headlight, and another one for the right side.
the current drawn from the the beam depends on what bulbs you put in. if you put a 100w bulb in high beam, and a 55w bulb in low beam, then the high beam will draw more power.
ericaagarcia
Jun 11, 2015 11:29 AM
intensity
May 12, 2015 10:43 PM
speedracersong
Jan 27, 2002 06:28 PM
tcneo
Jan 24, 2002 06:19 PM
