FF Drifting (with videos).
Back then, I thought that FF cars cannot drift; I thought powersliding is different from actual "drifting". After reading Honda Tuning,
They featured Keisuke Hatakeyama, a FF drift legend. You can visit his site (with his car) at: http://www.fdori-style.com/
Not believing that FF cars can drift, I did an extensive research on what exactly drifting is.
After watching the Drift Bible, Keiichi Tsuchiya, known as the Drift King, stated an entry level technique for drifting. Side drift, also known as pulling the e-brake, relys all on the e-brake.
Doesn't that apply to FF appkications? Tsuchiya never mentioned to step on the gas pedal during the corner.
Caucasian.Asian also posted an instruction of an "e-brake drift" from http://www.DriftSession.com.
Come to think of it, "powersliding" and "side drift (e-brake drift)" is a way to drift.
In bold, it does not say directly or indirectly that FF cars cannot drift. Therefore FF drives can drift. Then again, we all have our own definition of dirfting. Below are the vids I've mentioned. The vids maybe reposts, but the vids are just there to provide as evidence.
"Right click save target as..."
CRX drifting.
Civic (hatch) drifting.
Subaru Rex Turbo drifting. Yes they are FF layout. Click here fore specs (Subaru Rex Turbo).
How to side drift (Civic hatch) with FF Drift Legend, Keisuke Hatakeyama.
FF Drift Legend, Keisuke Hatakeyama, drifting against two 240.
If you like what I've compiled, rep points would be nice.
Originally Posted by Keiichi Tsuchiya
Pull the e-brake at the corner entrance and concentrate on making the car go sideways. You brake and then turn turn the wheel, step on the clutch and pull the e-brake. Release the e-brake, go into counter steer mode, then wait, wait until you know that the car is facing the corner exit direction then you gently start steping on the gas. How hard you should step on the gas pedal should depend on how much you're sliding and counter steering, all of this should get you to exit the corner, in one piece.
Drift
To cause a vehicle to exceed its tires' limits of adhesion, exhibiting a lateral slip, resulting in an oversteered condition.
http://www.driftsession.com/glossary.htm
not, rear wheels spinning throughout a lateral slip.
i consider it drifting, and it looks like there is so much more skills involved.
E-Brake Drift
This technique is very basic, pull the E-Brake or side brake to induce rear traction loss and balance drift through steering and throttle play. This can also be used to correct errors or fine tune drift angles. Main drift technique used in FWD vehicles.
1. Enter a turn at a speed too high for the vehicle to handle (if you do not drift, your vehicle should experience understeer at this speed).
2. Heel-Toe Downshift to get your vehicle into a gear low enough to pull you through a drift (2nd gear).
3. Turn your wheels sharply into the turn. By the time you finish downshifting and turning your wheels, you should be at the apex of the turn.
4. Hold in the release button on your E-Brake and pull up your brake sharply, then quickly release (e-brake is held up for only about 1 second). If using a RWD car, clutch in while pulling your E-Brake. If using a FWD car, keep on the throttle while pulling your E-Brake.
5. When you feel the vehicle’s rear end kicking out, immediately countersteer the wheels to face straight with the road. Your vehicle will pull in the direction of the front wheels, as long as the wheels are still moving. Keep on the throttle. If you press the brakes or let off the throttle because your vehicle is in an extremely oversteered condition, you will spin out or leave the road.
6. When you wish to straighten out your car, after completing the drift, let off the throttle smoothly and straighten out the wheels as your vehicle kicks in line behind the front tires.
Originally Posted by Epion
powersliding is a funamental skill of drifting... all this argueing bout what is a drift and what is not a drift is F-ing dumb. Using e-brakes deosn't mean that it's "noob" technique... different turns and situations take for different methods used to overcome it. E-brake drift is just one of these many techniques that can be applied to accomplish a "drift" turn. Even the "noob-est" of noob drifters know this..... F.... even people who watch Initial D understand the basis of this arguement. And yes... a FFD car can drift as good as a FRD...
Originally Posted by cdmx
you guys who keep saying a "REAL" drift doen't involve the ebrake Do not know what they are talking about....Theres LOTS of different techniques for drifting...Theres no REAL WAY....MABYE more difficult THATS ALL...sheesh
go watch the drift king bible
Originally Posted by Answers.com
Drifting is a form of motorsport in which the driver maneuvers an automobile to oversteer through an apex or straight, often with opposite lock. To perform this type of driving requires precise control over a vehicle, and sustaining such a drift for an extended period of time (and in a controlled manner) is often the object of drifting competitions. Because drifting is not the quickest way to take a turn, drivers are judged more on car control, technique, and style.
Furthermore, although nearly any wheeled vehicle can be placed into a drift for an instant due to loss of control, in general only rear-wheel drive (RWD) automobiles are capable of maintaining a controlled drift for an extended period of time. For this reason, sporty RWD cars such as early Toyota Sprinter Truenos and Corolla Levins (both cars are virtually identical), Mazda RX-7s, and Nissan 180SXs, which are relatively inexpensive yet were engineered with sophisticated suspension and rear-wheel drive configurations, are especially popular with amateur drifters.
The sport is particularly popular among young automotive enthusiasts in Japan, and the popularity has spread to the United States, Australia, Europe and various other locales.
In the 1930's, Tazio Nuvolari was the first driver to intentionally drift an automobile in order to corner faster. This technique became heavily used in the 1950's and 1960's before aerodynamics became prevalent in motorsports. Keiichi Tsuchiya, nicknamed the "Drift King" is one of the most famous drifters and is now an official D1 Grand Prix judge. He helped bring drifting to the mainstream by drifting his Toyota in Japanese touring car races, and participating in illegal mountain racing and drifting while still racing professionally.
Drifting in technical racing terms refers to a car's slip angle.
CRX drifting.
Originally Posted by Honda Tuning
Then one day we searched online and found a video clip, narrated in Japanese, of [Keisuke Hatakeyama] drifting an EF Civic. Not only he was drifting it, but he was also beating the Nissan he was going against. Whether this was an actual competition, demo or just friendly sparring, we don't know... Not only was [Hatakeyama] was drifting, he was also controlling the car in a manner of any top road racer.
I read that article too...I knew ff cars could drift already but I was always intrigued by how. I can't wait to download your videos to watch the cars closely. If you ever wanna see real ff cars drive hit california and hit a small city called Glendora. They have a road called glendora mountain road. Its usually only open in the summer because its soo narrow and curvy and has alot of hairpins. Just like in initial d alot of street cars that are both types of layouts come to drift the turns and race. Some nights there can be up to 50 cars parked at the peak of the mountain.
yeah, by definition a FWD car cannot drift. as stated it's called powersliding. it's a misnomer. just like we call nitrous NOS
i STILL consider it drifting. NO WHERE does it say drifting is only for RW drive cars, and if it does, someone provide a link.
oh, yeah. thanks for quoting me.
That is an excellent post. I was once ignorant, too, and swore up and down that a FF car cannot drift. But that is ignorance talking. After talking to people who have been in the drifting scene for awhile you come to realize how respected Hatakeyama is. If what Hatakeyama does on the track isn't drifting, he wouldn't have received the amount of acclaim or respect from his peers in the drifting world that he has. Drifting is more than what kind of car you drive. There are plenty of people driving around in FR cars that can barely cut the back tires loose. It takes a truly talented driver, one who is so in tune with the car that they have the ability to move the car's weight in ways that sometimes seem to defy physics. Bottom line: "Drifting" is not just the FR kids... even the real "Drifting" kids know this.
I'd send rep points your way... if only I knew how
Originally Posted by nookiemonster
It's not written, but it's common sense that a FWD car cannot induce oversteer without the E-brake, at which point it is not a drift, but a powerslide.
the definition of drifting is this.
using the car's power to break traction on the rear wheels, causing the car to slide sideways in a controlled oversteer before the apex of a turn.
a couple things here. A fwd car cannot do this controlled without using the e-brake. at which point, it becomes a powerslide, NOT A DRIFT. also, in FWD cars they generally do not do this until at or after the apex, which again, by definition is a powerslide, NOT A DRIFT. The reason a FWD car cannot do this before the apex of the first powerslide, is due to the fact that since the front wheels are the driving wheels, using the e-brake to induce a powerslide before the apex would cause the car to go off the track, rather than powerslide around the curve of the turn. A RWD car can use throttle/power to continue to push the car around the curve of the turn in a controlled oversteer before the apex. This alone is something a FWD can't even physically do because of the laws of physics.
So, sorry guys. FWD cars cannot drift, by definition. They can only do a powerslide.
however, as I stated, the sport of powersliding in FWD cars has become so popular they simply throw the term drifting in for simplification.
yup.
And where did you find that defination of drifting? You have to use the car's power to break traction on the rear wheels in order to drift? Then again, I guess Keiichi Tsuchiya, the Drift King, was powersliding in an S14 in the "Drift" Bible. Then what is side drift (e-brake drift)? Below I quoted and backed up with a source of what drift is.
Drift
Autocross Junky
Not nessisaily true... Throttle lift works very well, if you're trying to get a car to FF car to oversteer. Come out to our next autocross, its this weekend, Sunday out at Sam Boyd stadium. you'll see plenty of FF cars with oversteer issues..., all with out touching the E-brake.
^yup, just like rijowysock and his new TEIN FLEX
http://www.7thgencivic.com/forums/sh...d.php?t=201459
he said he can slide around sideways without even trying, but the posts got deleted???
Autocross Junky
THe problem with FF and drifting doesnt lie with weather or not Fwd can create oversteer naturally. Because you can easily tune a FWD car to oversteer. The problem lies with the Hows and whys. See, FWD can be enticed to oversteer naturally under braking (Corner entry) BUT. as soon as you get back on the gas for corner exit, you'll start to lose that Oversteer (weight gets transfered to the rear = more traction on the rear = Less oversteer). So inorder to maintain that oversteer past the point where you've gotten back on the gas to exit the corner, you must Force a loss of traction at the rearend... ushually with the E-Brake. (You can Heavily Left foot brake too...) With RWD, you get that same oversteer under braking as FWD, but you also get the ability to continue that oversteer after you've gotten back on the gas, by simply over powering the rear wheels. Thats the difference between FWD and RWD when it comes to drifting.
Originally Posted by aZnVoYCe
So what you're trying to say, the first method of drifting in the Drift Bible, which is side drift (e-brake drift), Keiichi Tsuchiya, the Drift King, was powersliding in a S14? He simply stated to pull the e-brake at the corner entrance then counter steer then wait until you face the corner exit direction then you step on the gas. Doesn't that apply to FF cars too? If that's the case, since side drift (e-brake drift) is a fundemental of drifting, then I guess powerslide is another term for side drift (e-brake drift)? And if that's the case, then FF cars can drift then. Correct me if I'm wrong.
Is this not the definition of "drift"? If not, then someone should correct them noh'?
once you are using more e-brake than anything to control your drift, it becomes a powerslide. obviously since a FWD car cannot control it's drift with anything but the e-brake, it's a powerslide. definition of powerslide is using the e-brake at or after the apex in order to control oversteer and slide through the corner. that's not what he was doing in the S14.
again, drifting involves using the engine's power to control the oversteer. something you can't do in a FWD car. in a FWD car you must use the e-brake to control your oversteer around the corner. this is a power slide.
starting the oversteer with the e-brake can be used in either method. it's what you control the oversteer with that determines whether it's a powerslide or drift.
Also generally when drifting, the loss of traction on the rear wheels is caused before the apex of a turn. This means that some RWD cars actually do a powerslide, rather than drifting, for the simple fact that they began their "drift" after the apex.
But, i see that Tsuchiya is trying to change the definition of a drift to include powersliding. If he "changes" it so be it, however, to the people that participated in the sport before his time, drifting and powersliding will always be 2 different things. It's interesting that a powerslide is called a power over, but then they say "oh well it's a form of drifting". Whereas I can simply say drifting is drifting. Again, changing the definition doesn't mean that drifting didn't use to mean something else.
Personally, I think it's stupid that he's trying to "change" the definition of drifting.
Also an interesting discussion I found on a japanese website.
http://64.233.179.104/search?q=cache...ient=firefox-a
as stated, he's trying to change the definition of drifting to include the powersliding that FWD cars do.
so this took you like what 10 min to put together, lol J/K that is alot of info, good job man rep points+
from drifting.com
Drifting is a sort of controlled loss of control of your car. When you drift, you use the weight and momentum of your car to move it laterally while it is still moving forward. In most cases, drifting is meant to bring the back end of the car around a turn faster than the front, while countersteering with the front wheels to maintain control and proper vehicle attitude. This is done by powering the engine to break traction on the rea wheels, and using that power to push the car through the turn. Alternately, a drift will occur when exiting a turn, when your outside tires are overloaded and lose traction, forcing your car toward the edge of the road. This is desirable because you can reach greater turn exit speeds by travelling at or near full throttle, but only if you can regain traction before your car slides off the road. Drifting is a knife-edge sort of driving technique, where you must be smooth and remain in control or else you will either slow the car unnecessarily or spin out.
As opposed to drifting, which is a controlled technique, sliding is a more wild technique with less control. A slide (or powerslide) occurs when all four wheels break traction after the apex and simply scrub along the road. Sliding is controlled by using the e-brake. Sliding is, in nearly all cases, slower than drifting for several reasons: First, you have no or very little traction during a slide, eliminating control of your car. When you are sliding, you cannot properly position your car for or during a turn as quickly and easily as you could while drifting. You must first slow your car until you regain traction, then adjust attitude. Secondly, you cannot accelerate as fast from a slide as you can from a drift. In rear-drive cars, properly accelerating from a drift will cause the rear tires to regain traction, providing acceleration. With a slide, you must again slow enough to regain traction before giving the car gas will do any good. The only time sliding is a useful technique is as a last-ditch effort to avoid going off the road or colliding with another object, or, sometimes as an advanced technique for off-road rally racing.
Powersliding is not drifting by definition.
Why is my vagina bleeding?
Of course it can oversteer, I have no idea what would make you thikn it can't. i oversteered powerslided my stock vic two weeks while hard cornering and braking while turning. The rear end was skewed out and I slid for a bit. And I didn't need to lock the rear wheels using the hand brake. Drive an RSX Type S that car is tail end happy even in its stock form.
^^right but what you did was for a very short time, hardly enough time at all. if a FWD car goes into oversteer by simply cornering too fast, and nothing is done to control that oversteer with the e-brake, or correct it, then you will spin out.
I think its stupid to say there is a true definition of drifting, it is simply entering the turn sideways, and taking the turn without losing control. An FF car can drift, it just depends on the skill of the driver. I really don't see any difference in drifting or powersliding as long as it is controlled. Drifting is an exhibitionist sport, and all approaches to driving sideways should be considered. Drifting evolved from touge races, so no one really stated the true rules of what is drifting and what isn't. But that's just me, if I see an FF car drifting good, i'll give a LOT of respect to that driver, because he deserves it.
Anyway, that's just my opinion.
Originally Posted by WyteAnjal
According to Keiichi Tsuchiya, drifting can be done in any kinds of car.
Definition of drifting by Keiichi Tsuchiya is as follows.
Start sliding in side before you start to turn.
Keep sliding and control your car.
If you can do that, that is called drifting.
source: http://64.233.179.104/search?q=cache...ient=firefox-a
from drifting.com
Originally Posted by VertigoEpidemic from Drifting.com
"FF Drift" (Front wheel drive drift)
The E-brake, steering, and braking techniques must be used to balance your car through the corner. The E-brake however is the main method used to balance out your drift.
source: http://www.drifting.com/forums/showthread.php?t=5561
Originally Posted by AutoPportz.com
What is Drifting?
Instead of a driver causing a drift into one corner and then countering to straighten out, he will instead over-steer his car so it will go into another drift around another corner...
E-Brake Drift: This technique is very basic, pull the E-Brake or side brake to induce rear traction loss and balance drift through steering and throttle play. This can also be used to correct errors or fine tune drift angles. Main drift technique used in FWD vehicles.
source: http://www.autosportz.com/article_what_is_drifting.htm
What is a powerslide? It says on http://www.driftsession.com/glossary.htm
Originally Posted by DriftSession.com
Powerslide
An American racing term for drifting that commonly refers to utilizing excessive horsepower to cause a loss of traction resulting in a drift.
source: http://www.driftsession.com/glossary.htm
Autocross Junky
You guys realize that the whole basis of this argument is simply what is the Definition of a Drift (as defined in the import world)
Drift in the race world is something completly different (almost)
Well, as I had pointed out the definition of drifting vs powerslide is different. And a FWD car can't drift, it can only powerslide.
But since it appears that the definitions are being changed to incorporate powersliding as drifting, what else can I say?
To many, myself included, drifting will always be what the current/previous definition of drifting is/was.
