just installed header and car runs like shit
just installed header and car runs like ****
i have a 03 lx. i just put on my new header with gets rid of the cat. and im throwing a code and car rans like ****. need indeas why my car is running like **** and oil psi is low help.
your throwing the codes becuase you initially got RID of the cat you need to get a tap and thread your o2 sensor into the exhaust and you also NEED and FREE FLOW cat i mean if you want to pass emissions. your 02 sensor reads your air fuel mixture in the exhaust and if you dont have a cat or sensor it will read incorrectly hense your car runs like CRAP
Well....I got a 03 LX too about a month and a half ago and I got me HP header W/High flow Cat and a cat back ......My car its been running great....I got the O2 sim sitting on my garage...Engine light goes off once in a while but its running great....I had to do some triming around to stop my car of being a massager.......What Kind of Header did you get???? did you get a Cat back too?...........
I had the same header installed on my car. I also had it installed without any 02 simulator with the stock 02 sensors. My car ran exactly the same as if it were stock. Just the cel light stayed on. I installed a MIL eliminator and it got rid of the cel. If the header is installed properly then you should not be having these problems. Check the installation for leaks. Did you use a donut gasket?
The Declaration of Independence was written on marijuna paper
Originally Posted by kornsined
your car went into limp mode. get o2 sim. BTW did you reset your ecu after the install?
Originally Posted by Ellocodetroit
I didn't know you had to reset the ECU. I thought after 500 or so miles the ECU adjusts to the improved flow of the exhaust fumes?
Originally Posted by mugenpower07
how do u restart or ecu?
4 cyllinders are good but 5 is better!
Emissions
We had a huge discussion on the LX headers last year! I bunch of people were saying to buy the ex header and just get a aftermarket hi flow cat with custom exhaust piping! And of course you will need the O2 sensor to fix the computer! But I do have one question! If you get all of this are you gauranteed to pass emissions?
CarStuff
Dec 6, 2020 12:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
beneditti
Jan 15, 2016 12:31 PM
