Wide Band o2 Sensor Location
A.K.A BlackCar --- Not From Califorina!
Just a question that came to my mind, where are u suposed to put that plug that comes with the wideband sensor? are we suposed to cut a new hole in the piping for it? or do we replace it with one of the 2 that are already there?
Also quick question, for the turbo people, when u first start your car, and the engine is cold, how long do u wait till u drive. Would u ever just start the car and drive it cold and just make sure u dunt hit boost till engine warms up? cus id figure the engine heat would make the oil hotter... thinner.. easier to flow to the turbo.
Originally Posted by Pedro Lopes
Weld the O2 sensor bung on the downpipe and before the cat.
DONT PANIC
Originally Posted by tfnaaf
i think some Wide bands will also suppost the ECU signal, ive also asked this quetion in anotehr post about the Zeitronix wideband wondering if its capable of supporting the ECU signal. Anyone know ?
Install the sensor into the downpipe before the catalytic convertor. This is the only place it will get an accurate reading without installing it into the manifold itself.
