Turbo is done!
Old Apr 1, 2003
Grey's Avatar
DIY King
Exclamation Turbo is done!
Notice how I wasn't posting for a while? Notice how I've been mentioning that I have a g/f now? Nope. I was working on the turbo. It's all done now. I'm at 8psi like RiceBurnerEX (spelling?) and I'm roasting the tires like crazy. Acceleration is unbelievable! Everything is just the way I wanted it.
Here's a quick list of the materials...
- T3 Super 60 turbo. (Ebay)
- Nice vertical flow intercooler with top and bottom end tanks. (Ebay)
- Greddy E-Manage FMU. (/w PC Link and MAP sensor and ignition harness)
- 450cc RC Injectors.
- Missing Link Valve. (modified)
- Custom Turbo Manifold
- ACT Clutch (holds 275hp)
- ACT Flywheel
- Aluminum charge piping. (mandrel bent, connected with silicon clamps)
- K&N air filter. (conical, their best one, big sucker too)
- Custom exhaust system. (titanium muffler (not the expensive one), 2.5" piping)
- Greddy Type-S blow off valve.
- Autometer triple guage pod and CF series guages (boost, A/F, and oil temp)
- Denso Iridium Spark Plugs (IK22)
- Stainless high-flow cat from J's Racing
There's all sorts of little trick things such as... Oil cooler and remote oil filter. Boost controller and boost creep inhibitor (basically a one way valve and a relief valve /w guages too!). Turbo is oil AND water cooled for longevity. BOV vent tube is routed back into the intake for less noise and to pre-spool the turbo a bit. The exhaust is not loud, but sharp and raspy (it's the titanium and the turbo!). Internal wastegate, but the vent tube is modified to be much lower than stock.
Programming the Greddy E-Manage was a bitch. I thought that I would destroy my car when I first started it up, but everything seemed to work nicely. I ran it rich at first so that I wouldn't run lean. Then I tuned in the whole thing using a wide-band A/F meter I borrowed from a shop for $50 a day. I had it for two days. Oh well, it was worth it. I now have an optimum A/F ratio throughout all rpm's at 8psi.
The turbo is a bigger one, but I guess I made everything as smooth as possible because it spools up at around 2,800rpm. Then the power just climbs and climbs. I can roast the tires in 2nd when I dump the clutch at 3,500rpm. Yeah, k3wl. This one place where I always accelerate is this little on-ramp that's nice and long and straight. I used to have an exit speed of 60mph on that one, but now I have an exit speed of 100mph. It's a world of difference.
I haven't done any stupid things like I did with the stock setup yet. No power shifting, no 6,800rpm shifts. I shift at about 6,000rpm's now just to keep it sane. :devil:
Yeah, one word. Insane! Turbo your car now! I didn't even have the money for it. I just maxed out my credit card. Whoops! It cost me exactly $2,158 for the parts. Another $100 for borrowing that A/F meter. Another $160 for borrowing a MIG welder. So I guess that's $2,418. Not bad. That's basically how much I wanted to spend.
Pics coming very soon! I have documented the whole damned thing. Took me the longest time to make the manifold. That sucker took a lot of time and planning to make. The Missing Link Valve gave me some problems, but I finally made it seal properly. The exhaust system was a cinch. I had bought all of the parts and i borrowed a welder for one day. I then melted all of the parts together. Easy.
Old Apr 1, 2003
xian's Avatar
Honda > Nissan
xian is on a distinguished road
Congrats Grey!!!
Do you still have your a/c or did you have to remove it? Not much room down there thats why I'm asking.
Xian
Old Apr 1, 2003
Grey's Avatar
DIY King
Yep, the turbo manifold took care of all of my space issues. That's one of the trick things too. The tubes go up and then down and the turbo kinda sits close to the block. It has more than enough room. Plus I made a heat shield to protect the fans and other heat sensitive things down there.
Old Apr 1, 2003
4bangin's Avatar
damn dude, sounds like a great setup. cannot wait for pics. you getting it dyno'd soon? to bad your blow-off valve is quite. i love loud ones. sounds sweet. anyway, congrats.
Old Apr 1, 2003
Grey's Avatar
DIY King
I might be doing a dyno. Don't know where to find a dyno shop around here yet? I might just take it to the track though.
I wanted the whole setup to not be that obnoxious, that's why I chose to route the BOV vent back into the intake manifold. Well, plus it improves performance a bit. Plus some people say it affects the MAP sensor. Don't know about that one, but I could disconnect it and see if my A/R ratio is different. I like it though; I can still hear it, it's just that it's muffled. Sleeper!
Old Apr 1, 2003
HomerSimpson's Avatar
GREY, in some places your would be considered a god with all your tech skills and DIY's
Old Apr 1, 2003
HCCriminal's Avatar
an0therpin0y
Congrats Grey ... now let me drive down to Shrewsbury, so u can make me one ... !!
Did u every consider making a custom manifold for our D17... with all the labor and materials ... how much would u charge for it ? .. i'm ready for the boost now .. !
Old Apr 1, 2003
CarbonFly's Avatar
Re: Turbo is done!
Sweet deal!!!
Old Apr 1, 2003
Ha0sVtecEX's Avatar
Ha0sVtecEX is an unknown quantity at this point
wooohaaaaa grey has a turbo ,,i wana see it ,,give us some pics,,pics pics i say ,,
ohh when you gona put a DIY for that turbo set up???
Old Apr 1, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
i call april fools on this one Grey...... mostly cause of the girlfriend part
Old Apr 1, 2003
noname's Avatar
Reppin' "Custom Concepts"
noname is an unknown quantity at this point
I going over your house to check this out dude
congrats
Old Apr 1, 2003
sawgunner06's Avatar
sawgunner06 is an unknown quantity at this point
Yeah PICS PICS PICS I want to see it YEAH YEAH. Good Job Man
Old Apr 1, 2003
Grey's Avatar
DIY King
Yeah, but it took a really long time to make. I ordered the materials from McMaster.com and from this local shop with mandrel-bent stainless pipe. Welding was a biotch since I had never done it before, but somehow I slapped the thing together. Looks good too. Oh yeah, it's pretty trick too 'cause it has anti-exhaust gas reversion built in. One pipe is smaller and leads into a larger one. The exhaust gases don't go back into the combustion chamber during the valve overlap. It was either that or a turbo cam and sucky low rpm performance. I chose something in betwean. I will not sell this manifold. Too long to make and people wouldn't pay me as much as I would like for it. Only big shops with many customers should be mass producing these things.
Old Apr 1, 2003
Grey's Avatar
DIY King
Working on it. Should be up tonight. Yes, the DIY will be up as well in about a week. There's a ton of pictures to upload and a ton of text to write in. I kinda started it already, but there's just so much to cover. I have over 250 pictures!
Old Apr 1, 2003
Hawk's Avatar
You boost, I-VTEC
So wait wait you bent your own intercooler piping? would you like to duplicate the prcess for a fee? i plan to do my own turbo project this summer using the same basics as riceburnerEX Revhard manifold, T3/T4 turbo. Only thing i really don't have a clue on where to get is the intercooler piping. So would you feel like making me some if you did make yours?? it would be highly appreciated
Thanks.
Old Apr 1, 2003
CivicLX620's Avatar
CivicLX620 is an unknown quantity at this point
I think I speak for many at this site when I say I wish I had the money, the time and most definitely the skill to make a turbo for a 7th gen. Props to you big man.
Old Apr 1, 2003
Grey's Avatar
DIY King
Thanks.
No, I didn't bend the intercooler piping. I got an intercooler off of Ebay. One that flows from top to bottom with end tanks on the top and bottom. One hole up high, one hole down low. I then bought aluminum charge pipes (2.25" ID, 2.5" OD). Some of them were just straight and some of them were bent. One was a 180 degree bend. I hacked that one up for several tricky spots (like the connection down low next to the windshield washer fluid reservoir). Three were 90 degree bends. The rest was just straight piping.
I wish I could bend my own. Then I would have a less restrictive system will a smaller drop in pressure. Alas, I don't have that sort of equipment. My method also required a fair amount of silicon clamps. Oh well. Got them off of Ebay for a good price. They work great too. They're the kind with the bolt stainless clamps instead of the screw type. Those are rated at some ridiculous psi (30+), so I should have no problem with air leaks when I crank up the boost. Which I will when I modify the internals.
Old Apr 1, 2003
AR's Avatar
AR
e-married to daydreamer
congrats you bastard. no no, only kidding. i am happy for you and your civic.
Old Apr 1, 2003
azure's Avatar
Congrats Grey! Can't wait for the DIY, pics... and possibly a dyno reading.
Old Apr 1, 2003
gotti's Avatar
Grey, you really are the Civic GOD of this site.
Congratulations, I hope you enjoy your new turbo.
Old Apr 1, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
grey is god!!! I can't wait to see pics
Old Apr 1, 2003
MadWheel's Avatar
Premium Boosted Member
damn you grey lol
Old Apr 1, 2003
Grey's Avatar
DIY King
So yeah, I think I've fooled you guys for long enough.
Happy April Fool's! Muahahaha!!!
Everyone in this thread got owned except MugenRacerX. Props.
Oh yeah, BTW... I really do have a g/f now and I really am busy with school.
Old Apr 1, 2003
azure's Avatar
NOOOOOOOOOOOOOOO!!!!!!!!!!!!
That's the THIRD TIME I've been fooled!!!!
D'OH!!!
Old Apr 1, 2003
gotti's Avatar
Grey....damn you. Your posts were so elaborate....GAH!@!
Old Apr 1, 2003
RSXtypeIvtec's Avatar
Su Mo
hahahaha......good one!
i was like, wow, Grey finished his project faster than i thought!
Old Apr 1, 2003
VRoomPSHeRt's Avatar
VRoomPSHeRt is an unknown quantity at this point
good job man! mad proppps!!!! post pix when you can, cant wait to see waht 7th gen power can do =P
Old Apr 1, 2003
I am taking away the god remark I made earlier
Old Apr 1, 2003
prototype's Avatar
x-factor
dude thats swet i cant wait to se ethe pix but correct me if im wrong grey, dont u have a digi cam and it will take 2 mins to post 1 or 2 pix.....and being that today is april 1st....hmmmmm i hope u got it tho sounds like a killer set up tho what did u do for the intake manifold?
Old Apr 1, 2003
pbfoot's Avatar
hey dude....HAPPY APRIL FOOLS TO YOU TOO!!! lol i for one am not falling for this one.
Edit: doh...i replied before reading all the way to the end. yeah dude..the whole girlfriend thing, and the fact that you told me before you wouldnt be doing a turbo kinda were a giveaway...hehehe
