Man thats aggervating
Welcome To Prime Time, BITCH!
So Tuesday afternoon my sub just stopped working. It didn't pop, no burnt smell, it just didn't move or make any noise. Well then I got the flu and today was the first chance I've had to check whats wrong.
I started the car and turn up the radio...nothing. So I checked the wiring....nothing wrong. The amp status light is still glowing green so the amp is fine.
Ok. So I pull the fuse in the engine bay and proceed to disconnect my system. I unhooked the sub box and pull it out, then pull the sub from the box and check the wiring...nothing wrong. I then unhook the amp and pull it out, and check the ground and power wires....nothing wrong.
I then proceed to put it all back together, carefully checking each wire as I wire it all back. Put the fuse back in, and start it up again. And again....nothing happens. DAMN!!!
Then I see it. Somehow or another the master/slave switch on the amp got switched to slave. I switched it back to master and "IT'S ALIVE!"
All that trouble for a switch in the wrong position.
sounds like you turned you MASTER INTO YOUR SLAVE>>>>thats the way to do that shiet! Hahaha....nah, if you were slumpin hard enuff it probably rattled the whole amp and moved the switch...but highly unlikely...like MeGaHuRtZ said, you were OWNED! Hahaha!
BBrosario
Sep 17, 2015 07:51 PM
