Man thats aggervating
Old Feb 27, 2005
GrayGhost's Avatar
Welcome To Prime Time, BITCH!
GrayGhost is on a distinguished road
Angry Man thats aggervating
So Tuesday afternoon my sub just stopped working. It didn't pop, no burnt smell, it just didn't move or make any noise. Well then I got the flu and today was the first chance I've had to check whats wrong.
I started the car and turn up the radio...nothing. So I checked the wiring....nothing wrong. The amp status light is still glowing green so the amp is fine.
Ok. So I pull the fuse in the engine bay and proceed to disconnect my system. I unhooked the sub box and pull it out, then pull the sub from the box and check the wiring...nothing wrong. I then unhook the amp and pull it out, and check the ground and power wires....nothing wrong.
I then proceed to put it all back together, carefully checking each wire as I wire it all back. Put the fuse back in, and start it up again. And again....nothing happens. DAMN!!!
Then I see it. Somehow or another the master/slave switch on the amp got switched to slave. I switched it back to master and "IT'S ALIVE!"
All that trouble for a switch in the wrong position.
Old Feb 27, 2005
tripledoublegs's Avatar
Euro-Spec
Glad to hear you fixed it. It can get pretty annoying...
Old Feb 27, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
dont you hate it when you do sooooo much work to only realize its was a simple fix.
i've been there myself
congrats on fixing the problem
Old Feb 27, 2005
MegaHurtz's Avatar
hehe owned
Old Feb 27, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
least you found that out before buying new subs
Old Feb 28, 2005
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
sounds like you turned you MASTER INTO YOUR SLAVE>>>>thats the way to do that shiet! Hahaha....nah, if you were slumpin hard enuff it probably rattled the whole amp and moved the switch...but highly unlikely...like MeGaHuRtZ said, you were OWNED! Hahaha!
BBrosario
Sep 17, 2015 07:51 PM
viperGTS
Jul 27, 2015 08:40 PM
