installing revo ss
installing revo ss
quick question on installing the revo... for the primary (??) cable there is a small plate around the cable (pic below). how do i remove the plate to get the cable out?
thanks cap for the pic
Escaped Convict
use a flat head screwdriver and pry it out.. slowly so u dont crack the stock assembly.
it should just slide right up out.
it gets a bit weaker after u pry it out though.. so after u reinstall it in the revo ss, might want to tape it down with hard tape or use different clips.
Yeah, use a flathead. Mine was on tight as hell, so it took a little more muscle, but dont rape it and crack the stock piece. Check out Grey's C-clips, I used them and they are good to go.
I wouldnt recommend using the stock clip since Honda uses a one-use clip and its loose like somethings that really loose.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
