Sponsored by:
Sponsored by: CARiD
installing revo ss
Old Feb 27, 2005
hman913's Avatar
hman913 is an unknown quantity at this point
installing revo ss
quick question on installing the revo... for the primary (??) cable there is a small plate around the cable (pic below). how do i remove the plate to get the cable out?
thanks cap for the pic
Old Feb 27, 2005
slicksivik's Avatar
pull up on the plate, it should slide right off i believe. then u just slip it on after.
Old Feb 27, 2005
CapYoda's Avatar
Escaped Convict
use a flat head screwdriver and pry it out.. slowly so u dont crack the stock assembly.
it should just slide right up out.
it gets a bit weaker after u pry it out though.. so after u reinstall it in the revo ss, might want to tape it down with hard tape or use different clips.
Old Feb 27, 2005
Nodnero's Avatar
Yeah, use a flathead. Mine was on tight as hell, so it took a little more muscle, but dont rape it and crack the stock piece. Check out Grey's C-clips, I used them and they are good to go.
I wouldnt recommend using the stock clip since Honda uses a one-use clip and its loose like somethings that really loose.
Old Feb 27, 2005
civic01vtec's Avatar
yeah, pry it out......it is tough, but u'll get it
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
