Camber Install
Camber Install
Does anyone know where I could get a camber kit front and rear installed at a good price? The kits (SPC) going on an 01 Civic Coupe w/ Eibachs Pro-Kit drop. Somewhere around the 310 area please.
The Standard One
diy.. its really˛ easy...
http://www.specprod.com/PROD_DIR/C_P...txt&cmd2=67230
http://www.specprod.com/PROD_DIR/C_P...txt&cmd2=81260
The Standard One
Originally Posted by born2xLr8
Any ideas on how to get the bolts loose on the rear. I've tried with a wrench and wow...they're on there good.
The obvious tip, make sure your not trying to turn the welded side. If its too hard, use a breaker bar.
hmm.. i dont remember them being on that tight... I remember the bottom bolt for the shock was...
They might be rusted on there. Anyone else get rust on their oem cambers?
The Standard One
just an extension you use for the wrench for leverage... get a peice of pipe, stick it on the end of the wrench and use that so its longer.
which one cant you get off? the one thats attached to the hub or the one thats attached to the chassis? if its the hub, just stand on that b*tch(wrench)
Originally Posted by Mustang5.0HO
Il do it for ya
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
