gahh what was that thing about the vtec light...
okie dokie i know about the DIY VTEC light and how it turns on at 3000rpm. but then i read somewhere a LONG time ago that the engagement point the light gives off was just the signal being sent from the computer and that the ACTUAL 9V signal that actually tells the engine to switch over to the high cam profile ocurrs at the peak toruqe range (around 4500 rpm). is that line tappable for like, a more accurate notification of the engagement point?
does anyone remember this little dispute?
It's true. The signal is sent at 3k rpms, but other factors are needed for actual engagement like 100% throttle, warm engine, enough oil pressure, over 4500rpms, etc.
so based on that little list (i know theres other factors), i tseems as if oil pressure is one of the more important factors. is there an electrical signal sent to trigger the engagement when enough oil pressure is attained (like is there an oil pressure signal line i can tap?)
and if there is one, would the engagement be set if enough current is flowing through the signal?
Well I think the most important is throttle. At full throttle, a 12v signal is sent to activate the cam change. This is the only factor that changes assuming the car is warmed up and functioning properly. The vafcII senses the throttle position, so I know there is a wire for it on the ecu (check the vafcII faq in tech forum).
wait, im not looking for total accuracy, but this light isnt going to kick on when vtec is not actually engaged will it? I know there is some lag time inbetween, but its pretty close, so it will light up then a second or two later vtec will kick in?
i would try to tap into the vtec soloid... best bet. Check the voltage on it with a multimeter and tell us how it goes ( kinda hard to do while driving but run a wire inside ur car )
New Mod on the Block
yes. Although the light comes on around 3k, and is variable depending on throttle position or rpms (or both), certain other safeguards prevent vtec from engaging. If the car is not warmed to temp, or the oil pressure isn't high enough, or the tps doesn't see WOT (wide open throttle-floored gas pedal), vtec won't engage. This was tested by a member using a data logger. They found that vtec would not engage unless the pedal was floored and rpms were hi (4000+rpms) to give the proper oil pressure.
When the tps senses full throttle, it sends a 12v signal to the solenoid that activates the cam switch. When the light is off or in low cam mode, it means vtec isn't on. But having the light on doesn't always mean vtec is on.
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
