Vtec and boosting?
Old Feb 19, 2005
sb143hd's Avatar
sb143hd is an unknown quantity at this point
Vtec and boosting?
I have a 2001 dx, and i swapped the enigine for a vtec! My dad did the swap while i'm stuck here in Iraq! the thing is he said he didnt have to switch my ecu.... is that right? is it even possible? I wanna make sure this wont be a big problem before I install my SF turbo kit! Thanx!
Old Feb 19, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
you will need a ex euc. dx ecu won't enangeg vtec.
Old Feb 19, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I think Xproductions (I think that's his username) used a VAFC to control VTEC on an LX ECU/EX head.
Old Feb 19, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
vtec controller p3wns you
Old Feb 19, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
You mean VAFC II???
I don't think VAFC works on our engine.
Old Feb 19, 2005
ajhdragon's Avatar
7thgens official a$$hole
an ex engine will run perfectly on a dx ecu, its just that the low- hi change over won't engage. im running an ex computer on a dx ecu with a vafcII, and the change over works fine.
Old Feb 19, 2005
Boosting Daily
so ur dad did an entire engine swap!? Waste of time IMO when all ya had to do were swap the heads. True Ex have higher compression, but for 12hp, big woot
Old Feb 19, 2005
allmotor's Avatar
nor cal 7thgens
do you already have the sf kit?
Old Feb 20, 2005
sb143hd's Avatar
my dad, called honda and they said all 01 up civics are vtec.... that can't be right? (and for your info i bombed my last engine)... and yes I already have my SF kit! So saying it's vtec, but i chose to use my current ecu, will I really lose all that much power considering I'm boosting?
Old Feb 20, 2005
2K1Civic17"Gabe's Avatar
this is just crazy.
DX and LX dont have Vtec. You can use a DX or LX bottom, with an EX head and have Vtec, which dont mean much. You can use your old ECU as long as you get a VAFCII. So you can set the Vtec engagement or something. It is probably like your running the same motor right now, and it wont feel much different after you get a VAFC II. You can get an EX ECU, but have to get your keys reflashed. Hopefully you understand all this.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
beanhead
Sep 24, 2015 12:04 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
