IS300 Suprise!
Boosting Daily
IS300 Suprise!
I was just crusin downtown looking for a shop i heard that may be hiring auto tech students. Anyways, on my way home, on highway 70 this white IS300 got beside me. i sped up a lil', and so did he. I slowed down a sec, and so did he. So then i layed on the gas and let off with a pretty loud PSSSSSSSSH. Then to my suprise, he layed on the gas and let off with a PSSSSSSSH of his own
Haha, the guy in the IS300 after that looked liked this--->
We didn't go at it cuz i knew, and i'm pretty sure he knew, i'd lose, haha. We knodded respectfully and went about our ways.
lol horrorskopes, you know better than that. a supra is WAY BEYOND anything an is300 is.
I'm not so sure you should go that far. Here is a NON supra bottom end 2jz engine boosted with a single turbo, no nitrous, on pump gas, clutch slipping and 1000cc injectors maxing out.
fastest IS300 so far on the board.
I wouldn't say that a supra is WAY BEYOND .... care to rethink it?
absolutely not. why?
a stock supra turbo can be pushed to the 600+ whp range on stock internals. the stock turbo can be used to reach 850+whp. not to mention it's RWD. sorry but i dont see any IS300's running a stock engine with stock internals and a turbo doing anything near that, much less being FWD.
sorry but that alone says supra > boosted is300 any day of the week.
s2000man......Just wanted to correct you. In stock form, Supras have 2 turbos. Not one. Oh and the IS300 is in fact RWD. Also I have yet to see a Supra with stock turbos put down anywhere near 850whp. Hook me up if you have proof. Not trying to bust your ***** bro. Just correcting you.
the supra and the IS300 share the same engine basically. The inline 6 2jz toyota engine is in both. The supra turbo model obviously is slightly different. Maybe you should do some research before you post the info. The dyno above was an IS300 you realize almost hitting 1000hp.
if you swap to the supra bottom end you will easily hit over 1000.
The tranny is different in the IS300 and supra. The supra uses a 6 speed, but many members on is300.net have swapped to the supra tranny when they push over 500hp.
the stock internals are basically the same....so yes the engine is a beast. It's one of the strongest internal engines out there, which is why the is300 can boost just like the supra can. The supra can come twin turbo stock though, which the IS300 doesn't have. The parts are interchangable though, so most people boosted on the board are right in line with the supra.
And yes the supra can go over 1000hp. But it needs different turbos, and internal work done at that, as does the is300.
the is300 is a beast just like the supra.
basically think of it as a SLIGHTLY younger brother to the Supra.
and they are both RWD. If you want to see dynos of an is300 doing almost 1000hp I can show you.
a lot of guys are running 11s on the IS300 bottom end boosted. Don't under estimate it
my bad on the RWD is300. thought it was a fwd car. i'm digging up more information on the supra. sorry, but i've never heard of an is300 being anywhere near the class of a supra. considering the supra is turbo charged from the factory. and i know the stock turbos can hit 650+whp. i've seen the dynos myself.
I can believe 650whp but not 850+whp on stock turbos.
I guess the IS300 is weak.
s2000 has left the building it looks like
to me, that means that if guys are swapping is 300 parts out and putting supra parts in, then supra > is300.
i'm not saying the is300 can't be fast. but i am saying that the supra > is300. your own post here confirms that. otherwise is300 owners wouldn't be swapping supra parts in. granted some of the engine is shared with the supra, but you admit in your post the supra got the better parts of the ones that aren't.
that's the point i'm making.
so almost hitting 1000 hp in the dyno above on pump gas, and no Nitrous isn't anywhere near the class of a supra huh.... hmmm.
you're right. the is300 can be fast... when you turn it into a supra.
show me dynos of is300's NOT running a supra bottom end or supra tranny or parts, and i gaurantee you the supra with the same amount of mods will push more hp and be faster.
i rest my case. supra > is300
ummm of course it's better. You made it sound like the IS300 is so much weaker than the supra, when in fact, they are very close. A heavily modified supra is almost the same as a heavily modified is300. The dyno proved that, which was on the IS300 BLOCK. NOT the supra block, which I posted. So the IS300 is capable of hitting those #s which is right there with the supra. Yes they swap parts. You think a stock clutch from a supra can take 1000hp? No, and they both use basically the same upgraded clutches, internals, etc.
of course the supra WITH a turbo is going to have stronger parts than a stock IS300. So I mentioned that guys who boost in the 500s use the supra 6speed to gain the gearing advantages. The stock IS uses a 5speed. And of course a tranny meant for boost is going to be stronger. But a stock supra tranny and internals will not hold in the 800s or 1000hp range, that's just crazy.
supra> is300. No question, and I never said it.
your previous posts made it sound like the IS300 was so much weaker. That guy hitting almost 1000hp is planning on pushing it harder and upgrading his clutch etc.
Like I said previously, don't underestimate it.
right... and how many supra parts did he swap into his car?
you don't have to TURN the IS300 into the supra. Basically it is a supra.
that dyno is a IS300 bottom end. The tranny is the same that an upgraded Supra would use. It's a modified tranny, not a stock supra tranny.
yes it will be faster.
but we both agree supra > is300. which is more of the point i was trying to make initially. it just came out bad.
i learn something new every day.
never said I know more about these cars. I learn something new about them every day.
yes supra> is300. But I'd much rather own the IS. It can be very much a sleeper. How about if he drove up next to the guy pushing almost 1000 wheel hp. That's a huge wake up call in a 4 dr lexus.
sweet *** IS in these vids check it
Boosted IS300's make me wanna
I wish i had one.
http://www.visionboy.com/
I wish i had one.
^^^ yeah, ive plugged VB and his vids in general forum twice, not much love I guess
. Anyways...
supra > is300
I like the is300, almost identical engines as the supra... just something about owning a supra is beautiful. Honestly, I rather have a supra than a boosted is300, but not to take away from it, ive seen these cars put on massive, monster HP/TRQ! They are sleepers.
. Anyways... supra > is300
I wish i had one.
I wish i had one.
yea supra > is300 but I don't mind to have either one
