passenger side light keeps fogging up!!!
Old Feb 8, 2005
mr_fobster's Avatar
well i just just resealed them with 3m window weld but again once i put it back on today it started fogging upa bit(not as bad as the litle lake i had it is before) but im just worried that it will start condensing again! but i think i might know wat the prob is. the passenger side fender is like hitting against the top left side of the passenger side headlight, and i think it is causing it to rip some of the window weld around that portion of the headlight and making a little hole. ill post pics of wat i am talking about tomm.
but if thats the case would i be able to move that fender around so that its not so tight together with the headlight? or i could be wrong all together and the seal is bad, but nothing looks like its sticking out or anything like that. everything looks tightly sealed.
but tomm ill post pics up of my fogged up light and ill post pics of wat i mean by the fender hitting up against the light. but any suggestions right now would be very helpful.
Old Feb 8, 2005
mr_fobster's Avatar
ok here are the pics now:
http://www.villagephotos.com/pubbrow...der_id=1212581
on the third pic you see on the first row, thats the good light that hasnt fogged up every since the first time i opened it up!
i am thinking of getting these so that i could just have no more probs with fogging wat so ever:
http://www.robearracing.com/pd_honda..._black_gun.cfm
but i have a feeling that it may fog up to
oh yea also i think it might be that the light bulb connector(watever its called) is loose and is making it condense like that.
Old Feb 9, 2005
dirtySAMURAI's Avatar
I log in from time to time
you might have to take your headlight off and dry it by hand. i think when you first blacked out your headlights, you may have gotten a little bit of water stuck inside the housing, and after you sealed it all that water stayed inside the headlight...so after a while it will dry, but it will remain inside the headlight as a water vapor...and then return to the liquid state when it's cold.
Old Feb 9, 2005
gh0st's Avatar
TAQUITOS!!!!
try the hair dryer trick. open it up as if you're changing a bulb, aim the hair dryer, and let it dry it all up...i dont know how long you'd have to do it for
Old Feb 9, 2005
mr_fobster's Avatar
yea but if i do that wouldnt the fog just come back? and when i resealed the light again i did dry the lense. i took everything apart and wiped off all of that water on it and it still came back....but lately it was nt as bad as it was before9when there was like a river in my headlight) so for now its just small pacthes of fog here and there. but im still **** about it. from far away you can barely see it. but once your up close you can see it for sure.
Old Feb 9, 2005
gh0st's Avatar
TAQUITOS!!!!
have you thought about something else to seal it aside from what you're using? the diy's call for clear silicone just a suggestion
Old Feb 9, 2005
kismylx's Avatar
kismylx will become famous soon enough
Thumbs up
my passenger side use to fog up all the time when it rains or its very humid outside but the reason i think it use to fog up is a little drop of water may have gotten in the headlight that you can't see. so what i did was removed the weatheseal from that headlight and drove a car for a week and the air getting inside the headlight must have dried it up and no more fog and put the weatherseal back on......
Old Feb 9, 2005
mr_fobster's Avatar
ok the 3m window weld is clear silicone type stuff. this is one of the best stuff to use when doing this, since it dries up almost instantly. what im thinking of doing is using fogX on the lenses. has anyone have any experiences with this?
Old Feb 9, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
take it off and take it to a dry enviornment (not humid) and let it dry out, worst case you open it and dry it out...and silicone is your friend
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
werdnahall
May 17, 2015 11:37 AM
crowtoo
May 11, 2015 06:50 PM
big20ugly
Nov 11, 2001 08:30 PM
