Sponsored by:
Sponsored by: CARiD
Fiberglass Body Kits!
Old Feb 4, 2005
matt_s's Avatar
Super JDM Member
matt_s is an unknown quantity at this point
I have read around that sometimes they require a lot of work to put on. Is this tru, and is the quality really that much worse than polyeurathane?
Old Feb 4, 2005
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
Very true. Urethane has some flex in it, and it much more durable. Fiberglass cracks like crazy. Especially you living in st kitts, with the snow and all u'll be sorry. I had a fiberglass kit on my previous car and it was a nightmare.
Old Feb 5, 2005
import2nr's Avatar
awd pwnz j00
fiberglass is horrid, get urethane
Old Feb 5, 2005
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
I have a fiberglass front and urethane sides and rear.. the fiberglass has held up just the same as the sides and rear..
whatever floats your boat really..
Old Feb 5, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Urathane will cost you alot more plus good luck finding a kit you like!. Fiberglass is fine I have no problems with them in the past. Urathane is a good way to go but, either way you get chips in the paint no matter where you live. Fiberglass is very rigid and can crack easy, hence you'll definetly have to watch where you park and stuff like that. good luck in any case.
Old Feb 5, 2005
matt_s's Avatar
Super JDM Member
thanks for your posts... would the cold of the winter and snow cause more cracks in the fiberglass or no? like wats the main reason for these cracks to appear?
Old Feb 5, 2005
04vic's Avatar
04vic is an unknown quantity at this point
urethane in hot climate can droop and rough roads can cause spider cracks in kit even with flex paint...
Old Feb 5, 2005
Berg_Tomaru's Avatar
Poor quality fiberglass kits will be a pain in the rear to install, sometimes they won't fit exactly and some cutting/gluing/hole punching has to be made. Also it cracks way easier than urethane. Without $$$ in concern, go urethane but if you want to save, a good quality fiberglass kit would do the job. Good luck
Old Feb 5, 2005
Transformer_Guy's Avatar
Lost in the Matrix
Transformer_Guy is on a distinguished road
The cold weather will make the fiberglass more brittle and will be easier to crack or damage. I picked up a fiberglass kit from VIS and the body shop still had to do a lot of work to make it fit properly. The main reason for these cracks to appear is that people dont take care when driving...
Old Feb 5, 2005
ex_03's Avatar
Godlike member
I disgree with the whether being an issue, people buy fiberglass windows for the reason that the whether doesnot effect them at all. But its mostly driving. Watching when you pull into a driveway that its not too steep (knowing your limits, in inches if need be). Parking blocks pot holes ...just stuff like that. Urathane will be brittle in the winter and soft in the summer.
Old Feb 5, 2005
cambo's Avatar
I wish I was asian
people buy fiberglass windows because they're lighter.
Also, think about other drivers and all the rocks they throw up. a rock will crack the bumper instead of just making a chip in the paint.
Old Feb 5, 2005
fastcivic03's Avatar
fastcivic03 should not be trusted
Dont get fiberglass my friend has one on his jetta he crashed going about 10mph, and totally ****** it up, now he has a urethane one and seems to be holding up. When I put my kit on in summer deff going to be urethane...
Old Feb 5, 2005
Wolfgang5884's Avatar
I say go urethane, plain and simple. I just saw too many fiberglass kits get messed up so easily
Old Feb 5, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
why dont they just make aftermarket kits of the same material they make the factory ones of? would this not make sense? fing morons!
Old Feb 5, 2005
MSL's Avatar
MSL
MSL is an unknown quantity at this point
i've never had any cracking problems with my fiberglass kit.
Old Feb 5, 2005
UNORTHODOX02's Avatar
UNORTHODOX02 has a little shameless behaviour in the past
The main reason for cracked fiberglass is the driving, the cold weather has nothing to do with it. I install/sell truck and car accessories, and i sell fiberglass running boardsand truck caps all the time. And I live in new england. its very cold around here. The steps hold up awesome, they're not as low as a body kit, but they do take a beating. all the rocks and stuff kick up from the front tires and bounce right off. Basically, its the driving. Like he said know your limits. fiberglass can take quite a beating, paint cant. Whatever you do, dont go the cheap route, get quality.
SammySC
121
Apr 7, 2017 07:43 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
anubis62
Sep 27, 2015 12:56 AM
General DIY
Sep 25, 2015 08:02 PM
Bricoleur
Sep 9, 2015 12:30 PM
