dash lights are out!
Old Feb 4, 2005
drunkenmagnum's Avatar
my dash lights are out- whats wrong? i cant see my speed or rpm. is it a fuse or another problem?if it is a fuse which one? i dont have my owners manual right now.
Old Feb 4, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
check to see if your rear tail lights are out. If the fuse is blown then your tail lights will also be out. Sometimes if you have a rear light out it will also shut down the dash lights they are tied into the same curcuit. If you look at your fuse box under your steering column the fuse will be labeld.
Old Feb 4, 2005
yeah both tail lights are out - so which one is it- the diagram isnt very usefull
Old Feb 4, 2005
cmeias's Avatar
I am not sure I dont have a manual for mine either it should be a 10 amp circuit. if you have a multimeter then you can check each one in the socket if not you will just have to pull each fuse one by one. You can tell if it has popped by holding it up in the light and between the two silver posts will not be connected. let me know if you find it. It should be a red one.
Old Feb 4, 2005
thanks - found it. now to find some fuses!
Old Feb 4, 2005
streetglower's Avatar
you need to find out why it blew. Fuses dont just blow for the hell of it, something caused it.
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
antidote11
Dec 8, 2001 09:32 PM
