DIY: oem switch for oem copy foglights
Old Feb 2, 2005
ferio's Avatar
ferio is an unknown quantity at this point
this is for anyone who has an 02+ who has/will get the oem style foglights...
i just decided to post this in the tech stuff forum becasue a couple of guys asked me which pins go to where regarding with the oem switch (telly you owe me **** dude)
here is the comparison:
the one on the right(blue) is for the 02
here is the diagram as to where the pins go:
now i bought my foglights about a year and a half ago so i forgot how it came with/like( i think i had to remove the pins from the white plug that's supposed to fit the old switch). so if you have questions about this diy just post 'em up. i think the diagram is pretty much self explanatory though.
Old Feb 2, 2005
Da1lyDr1ver's Avatar
i installed foglights on my friend's '03 civic and for some reason, the OEM switch will not stay in place where the cutouts are. it doesnt even snap in place, so i thought i was missing clips, but its not the case. any ideas?
Old Feb 2, 2005
My switch for 02 is kinda loose too. If you're worried, just glue it from the back with some cement glue and tape it to dry overnight. Should be good to go.
Old Feb 2, 2005
i just dont get why OEM parts dont work with the damn car. it doesnt make sense. well, i'm not gonna worry about it. i personally wouldnt glue it either incase i wanted to remove it or something later on. but thanks for the advice anyways
Old Feb 2, 2005
wonderz's Avatar
wonderz is on a distinguished road
is the diagram for the left switch or the right one?
i have the switch on the right, can u tell me what wire goes to which pin?
and i assume black wires are ground, red wires are power wire, and yellow is the switch wire?
Thanks
being looking for this for a long time.
Old Feb 2, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
yay! i wanted to do that in my 02, but i need to find a decent price swtich, im not paying $30 at the dealer! right not, the switch is being held in by epoxy glue. sticky this?
Old Feb 2, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Hurray! Which email address can I send the asian **** to?
Old Feb 3, 2005
wonderz's Avatar
and are black wires = ground, red wires = power wire, and yellow =switch wire?
bumping it up for question.
Old Feb 3, 2005
2k2silvcivic's Avatar
2k2silvcivic is an unknown quantity at this point
about the switch not fitting right. I had the same problem, are you trying to put it below the radio or by the cruise control. If you try to put it below the radio it will not fit( or at least mine didnt) If you put it in the spot by the c.c it should snap right in.
Old Aug 14, 2005
G-4dr's Avatar
G-4dr is an unknown quantity at this point
Exclamation
Hi ferio,
Can yo post again the diagram i can't see.
Thanks for you help.
Old Aug 14, 2005
TeLLy's Avatar
ferio helped me out with this way back, so i'm just passing on his kindness once more (from his own member's rides gallery):
Old Aug 15, 2005
ferio's Avatar
where is my asian **** telly! i forgot about that! hehehe!
Old Sep 4, 2005
TeLLy's Avatar
Shoot me an email address and I will send you more **** than you can shake a d*ck at.
Old Sep 28, 2005
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
okay i have the switch...how did you guys connect the pins together? lilkd solder it?
Old Jan 3, 2006
TuRtLE714's Avatar
bump...i want to do this but pics dont work no more
Old Jan 3, 2006
ragingSPAM's Avatar
I just burnt my tongue
i havent seen an OEM switch yet but if the connectors are anything like a relay connectors than u can use female spade connectors and crimp a wire to the other end...just make sure u have the right wires spliced together
Old Jan 3, 2006
TuRtLE714's Avatar
can anyone link a site where i can buy the connnectors? i check radioshack and autozone and all of them are too big
Old Jan 31, 2006
riceboi's Avatar
riceboi is an unknown quantity at this point
Bump.
Would someone be kind enough to post the pics again?
Thanks!
Old Jan 31, 2006
Karumba's Avatar
Boredom causes changes ;)
Pictures are still in his gallery - just mislinked as the forums have been updated since this DIY.. Here it is though:
Old May 20, 2006
es2k2's Avatar
Proud to be a civic owner
my ebay kit only has 2 wires to the switch... i think they should go to the ground and the power but where do i find the yellow/switch wire? the color of my wires are kinda messed up
Old May 22, 2006
mrchowmein's Avatar
I've recently rewired my fogs, i had an 02 replica. anyways, i bypassed the relay cuz the wires near the relay melted. so there should be 3 wires for the switch. The source (+), the ground (-) and the power wire leading to the foglights (switch wire). there should be only one wire coming out fo the foglights besides the ground. Mine was a blue wire. So i connected the blue wire into my switch. remember do not mix the source or ground wires on the switch. if you dont know what youre doing, it might be handy to have a box of extra fuses too just incase you do something. heres a picture of my switch wiring layout. i hope it helps. If you dont have a switch, you could get one from Pep Boys or some other auto store. Just get one with 3 connections.
Old Nov 16, 2006
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
good thread needed this
Old Nov 21, 2006
burke420's Avatar
The World Is Yours!
will the eom switch NOT work with any copy fogs... i got the Password:JDM fogs, and i wondered if itll work
cukaracha
30
Jul 26, 2015 12:01 PM
Jul 12, 2015 11:54 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
BootyDo
Jul 7, 2015 06:06 AM
hatch90
Jul 5, 2015 01:17 AM
