hid conversion kit problem....help
im putting an rsx front end on my car and in the process i want to add an hid kit. the rsx kits i found say they have two hid bulbs. im pretty sure rsx headlights use different bulbs for hi and low beam so would i need to just put hid for lo beam and suffer with stock hi beams or how would it work?
Search and Learn
High and low beam are totally different.
They have bulb for low beam and another for high beam.
Just do retro fit on low beam and use reg rsx high beam.
And you will have to redo whole lighting hareness for conversion anyways.
Get yourself helm guide and start studying for light wiring diagram.
Good luck.
Good luck.
stock high beam is better than HID high beam. yellow will cut through elements...not that you would want to drive around with your high beams on all the time.
Hutch1051
Sep 29, 2015 09:20 AM
TheRiddicles
Sep 21, 2015 01:28 AM
