Power Stearing Fluid
Old Jan 29, 2005
runner1738's Avatar
My power stearing fluid resvoir isnt able to stay full about a week and a half ago i filled it up with a whole bottle of fluid and its already below the line right now and make the sound like its straining or whining, any idea why?
Old Jan 29, 2005
streetglower's Avatar
you have a leak somewhere. Usually indicated by a whinning noise. You need to locate the leak and repair it. could be in the steering rack, power steering pump, or the hoses.
Old Jan 29, 2005
runner1738's Avatar
should i just take it honda?
Old Jan 29, 2005
If you arent mechanically inclined to work on your car then yes, but jack your car up and inspect everything. If it is a hose, just replace it. If it is the pump, you will need to replace it, or overhaul it, but easier to replace it. Same with the rack. Those might be cheaper to overhaul though.
Go to an independent shop. they will charge less.
Old Jan 30, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
You really don't need someone to tell you whether you need to take it to a mechanic. If you have a problem with your car, and you can't figure it out, it is very logical that a professional would do a better job. All everyone here can do is guess at your problem and suggest fixes. Ultimately, you still have to take care of it.
Old Jan 30, 2005
runner1738's Avatar
true but i guess my real question was should i take it to honda or try and find another shop? also what kind of shop? i looked at it when i parked and nothing seemed leaking from the resvoir on down so maybe its the pump which either way its gonna be expensive right? i was also just asking for tips on how to check what part of my car might be wrong
Old Jan 30, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
ok this is how u fix ur problem
go to the nearest auto parts store
ask for oil leak detector
put it in ur ps resevoir
go buy a black light
drive home
with the black light in the garage fash it any where the ps componets are
where u see a bright green
U FOUND THE LEAK
the rest is up to u
Old Jan 30, 2005
drive home
U FOUND THE LEAK
the rest is up to u
or you can just open your hood and take a light and look for the leak. Power steering fluid is easy to spot. No need for any leak detection crap.
Old Jan 30, 2005
koolaidman's Avatar
what if its 1 of the lines on the gear box...if ur spill a lil bit of oil u could mistake it for something else...witht he leak detector...ull find it with out a problem
Old Feb 10, 2005
runner1738's Avatar
is any of that stop leak stuff at pep boys any good , when i went in to get more fluid ( i know temporary solution before it drains again) i saw they had some no leak things for power stearing saying will stop small leaks and what know, worth it , any good? any harm if i use it?
Old Feb 11, 2005
did you even look to see where the leak is coming from? It could be as simple as a hose. I wouldnt use that stuff, just dont trust stuff like that. Get the problem fixed.
Old Feb 11, 2005
runner1738's Avatar
yea ive looked but tis not like i leave my car for an hour and see a puddle or its dripping out, just thought i would try a $5 dollar fix first then, if not it then take it in, is this not something that should be covered under warranty?
Old Feb 11, 2005
What you need to do is open your hood and take a flash light and examine all around your power steering pump and resovoir and then look at all the lines. Then get under your car and check the power steering rack. A small leak can cause fluid to gather around certain places and not drip, but still cause a lot of fluid loss. Depending on what type of warranty you have, will depend on if it is covered.
Old Feb 12, 2005
runner1738's Avatar
thanks, some people have mentioned they have the honda care warranty but i dont think we ever got that, so im pretty sure its just the basic one
Old Feb 23, 2005
runner1738's Avatar
covered under warranty they said it was the power steering rack leaking, and they replaced , teh box assy. and washer, tie rod l, is the name of things they replaced
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
hans.pcguy
Jul 12, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
