Race tire opinions needed
Well first off I should say that i bought some 15 x 6.5 rota sliptreams last week and now im in the process of looking for tires. These new tires will be used in the summer only and I will be drag racing in them. I have a neuspeed sport spring drop and I want to try to keep close to that wheel gap I have now with stock tires. The tire size I am leaning towards is 205/55/15 tire size. I need your guys opinions on what tires to buy that are optimal for straight line traction. Ive found 2 in that size and they are yokohama Avs es100 and the dunlop Sp sport fm901. Any opinions on these and does anyone know of other good tires for drag race that can be found in that size. I would also consider 215/50 size but there aren't too many tires in that size. Any opinions and personal experiences would be great. Help me pick my tires guys!!!!!!!!
If you plan on just drag racing then get a tire with soft sidewalls (cushions load and allows better hookup upon launch). I think the Yokohama es100 and Dunlop fm901 have stiff sidewalls (to minimize sidewall flex upon turning).
I suggest the Nitto NT555R or the BFGooodrich street drag radial for your application.
Or you could go the extreme route and get dedicated DOT approved drag radials (Mickey Thompson ET street tires).
Search the tire sizes you are looking for at tirerack.com.
Hope this helps.
Hope this helps.
Hmm those tires are nice, but I dont' think they are in my price range or in that size I need. Would the Yokohamas or Dunlops work well for drag or should I not even bother? Any ideas where to find good tires in the 205.55.15 size? Post Links! thanks
two whole different things. the avs es100 are ok for traction. good for street.
if u want some real race tires, get some hoosiers or micky thompsons for the track
I guess what i really want is some real sticky tires that I don't have to take off every time i'm done racing that i can drive on the street and highway and what not. Ive heard that azenis has a real stiff sidewall as well. The dunlops have a treadwear of 200 same as the azenis which means more then likely they are about as sticky as the azenis. Are dunlops junk or should I seriously consider them?
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
