how do you jack up the whole car?
Old Jan 26, 2005
Jotosuds17's Avatar
Jotosuds17 is an unknown quantity at this point
i'm thinking of DIY the MTF change cuz honda wants to charge $90. but i read the DIY and you have to jack up all 4 points of the car.
i was thinking:
1) jack up rear left, place jackstand, lower jack
2) jack up rear right, place jackstand, lower jack
3) jack up whole front, place both front left and right jackstands, lower jack
and to drop it back down, just reverse the process?
oh yeah, i'd have to buy 4 jack-stands and a jack, plus the MTF fluid. how much do you think it'd be? thanks.
Old Jan 26, 2005
shmik1's Avatar
jack and jackstands ran me about $28ish @ walmart and they're good quality.
Old Jan 27, 2005
Jotosuds17's Avatar
cool thanks.
can anyone help on the method in jacking it up/down?
Old Jan 27, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
use a lift!
Old Jan 27, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
just like you said.. its better if you have 2 jacks that way the weight is distributed evenly
Old Jan 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Locate front Jack point under bumper, lift whole front end, put jack stand on each side per owners manual. Jack up rear end from the suspension subframe (the box like structure in the center where the LCAs bolt to. Put 2 jack stands under the rear as specified in the manual.
Do work, reverse process. Always lift/lower the front first, or you stand the chance of not being able to get the jack out.
Old Jan 27, 2005
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
Drive that Bad mother onto a set of ramps and then jack up the rear.
Better yet... get a funnel and stretch of plastic hose duct tape it together to form your MTF Bong and just crawl under the car and stick it in the hole...
Thank god I'm Skinny... you also need two people for that.
This is cool how everone is saying 4 jacks and 2 jacks and jacks jacks jacks jacks... i feel special
Old Jan 27, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
90 buckS?!?! I really think oil changes and Tranny fluid changes should cost the same 20 bucks. I mean all they do is open the drain bolt, drain fluid, put drain bolt back, (filter for oil), pour new fluid. wam bam thank you mam.
Old Jan 27, 2005
4jacks's Avatar
filter ?
Old Jan 27, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Need:
4 jackstands
1 hydraulic jack
Front:
Find the front jack point. You can feel it right behind where the bumper ends, under the car, and if you can get under to look there's an arrow pointing to it. Jack up the car high enough and you can place the jackstands under either front side jack point (roughly 10" behind the front wheelwells).
Rear:
Stick the jack under the subframe, right behind where a rear lower tie bar would be installed. Raise it up then you can stick jackstands under the rear side jack points (6" in front of the rear wheelwells).
The problem with using the side jack points to raise the car is that with a hydraulic jack and jackstands you won't have any room to switch between them once the car is up. This will necessitate jacking up the car from a non-reinforced area, bending metal...
Old Jan 27, 2005
4jacks's Avatar
Originally Posted by TeLLy
4 jackstands
dammit Telly you're a kill buzz
Old Jan 27, 2005
Jotosuds17's Avatar
thanks dudes. i wanted to do the whole front/back as you guys described.
so raise front, then rear. then to get it down again, lower front, then rear?
Old Jan 27, 2005
againifall's Avatar
Go Team Venture!
nah once yer set just get another person and just push the car over... hehhee ok dont do that.. yes.. drop the front then the rear
Old Jan 27, 2005
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
How long (miles) untill u change the MT fuid??
Old Jan 27, 2005
PunkingCivic's Avatar
I need TP for my bunghole
Got spare cash and have a garage?
Get this.
$900 - http://www.harborfreight.com/cpi/ct...temnumber=46604
Old Jan 28, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
internal filter that, i think, locates inside the oil pan. the filter usually comes w/ oil pan gasket and its more than 20 bucks for the kit.
90 bucks sounds reasonable w/ OEM products.
Originally Posted by 4jacks
filter ?
Old Jan 28, 2005
civic01vtec's Avatar
IMO..........if you need to ask this........you shouldn't be using tools.
Old Jan 29, 2005
4jacks's Avatar
I should really stick my head under my car instead of babbling on...
BUT isn't the Manual Transmission Fluid Pan (not the oil pan) a SEALED UNIT???
well the oil pan is sealed too ..
Maybe you're refering to an AUTOMATIC Trans Pan!?!?!? I'm not sure about civic's, but yes on a lot of those you have to actually Drop the pan and change a filter... in the Manual.. there is no filter.
Old Jan 29, 2005
4jacks's Avatar
... no one asked for your demeaning opinion... everyone has to start working on cars somewhere.
The point is this guys is asking to make sure that he is doing this safely..
so if your not going to be supportive, or informative, then at least say something funny.
Old Jan 29, 2005
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
Well I haven't had any reason to jack up my 04 yet, but if you need the whole car off the ground I would think that jacking up the left rear pretty high, then you could place both jack stands under the left side of the car, then jack up the front from the left side if necessary, raise the front jack stand. go to the right jack up the rear jack stand on the right rear, jack up the right fronr jack stand it, I think that's how I'd do it.
Old Jan 29, 2005
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
i changed my atf awhile back and it's simple you really only need 2 jack stand or a pair of ramps. i drove up on ramps, pulled ebrake up, undo atf drain bolt, clean metal shavings off magnetic end of plug, put bolt back in, and put in new fluid. honestly this process is easier than changin oil and is shorter since there is no filter to replace.
Old Jan 29, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
There is no way to get to the auto filter without completely dissasembling the transmission.
Old Jan 29, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
wont the jack stands cost more then honda would to do the service?
take it to a local garage
Old Jan 29, 2005
4jacks's Avatar
Dude that is blasphemy! Even if it did, The jacks would cost less than doing it twice. Regardless of the other infinite uses for a good set of jack stands and some ramps...
Every REAL man needs a set of Jack Stands and some Ramps. . . Owning a Car With out them it's like trying to look tough drinking through a straw.
Old Jan 29, 2005
good point
/me retracts previous post
Old Jan 30, 2005
SevenCyrus's Avatar
I got ramps, THEY SUCK, lol if your car is lowerd be prepared to scrape.
Old Jan 30, 2005
4jacks's Avatar
yes Store bought ramps to suck big time...
What you have to is this
Buy a 6ft long 8" x 8" exterior grade post (wood)
buy a 12 foot long 2" x 12" board ...
then you cut the Post into two pieces with a chain saw.
BUT NOT DIRECTLY IN HALF.
You start a foot off from one end and end up a foot from the other end diaganolly. (this gives you Two Ramps !)
Then you cut the board directly inhalf and screw it to the bottom on the two ramps you made... )
I'll take pictures next time I use the one's we have)
It's great though... first the car goes up the 2" board... the the ramp is very gradual and you won't scrape... plus wood holds a lot more wieght.
Old Jan 30, 2005
SevenCyrus's Avatar
Nice.
Old May 22, 2008
black01's Avatar
black01 is an unknown quantity at this point
Re: how do you jack up the whole car?
does anyone have a pic(s) of the front and rear points where the jacks should be placed?
that would be really helpfull!
Old May 23, 2008
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
jackstands from sears.
