Are these springs correct?
Old Jan 22, 2005
morgan040's Avatar
morgan040 is an unknown quantity at this point
I just received my adjustable springs from ebay, and they all four look alike. Is that correct. My stock springs have a large style spring up front and the rears are the small ones.
Why would my new generic springs all be the small coils???
Old Jan 22, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Coilover springs are straight rate springs. They should be either 2.25 or 2.5" in diameter.
If you bought some no name off e-bay, probably the best thing you could do with them is send them back.
Old Jan 22, 2005
morgan040's Avatar
am I supposed to use that huge lower stock sring perch (front) with my new 2.5" spring
Old Jan 22, 2005
flotsamm's Avatar
No you cant use them safely. The front springs are different then the rears. Sounds like you got a coil over set or two sets of rear springs. DO NOT install the smaller diameter spring in the front stock strut. The front spring seats into the upper rubber isolator and the lower part of the spring butts up against the lower perch so the spring doesnt move.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
skeener51
Oct 1, 2015 05:56 PM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
