DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Old Jan 2, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
www.home.earthlink.net/~profuse007/id3.html
finally got around to do this write up..... just got camera (some pic blur)
have fun
Old Jan 3, 2005
Civicly02's Avatar
cool thanks. my auto start was not working because I had no idea on how to do it
Old Jan 3, 2005
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
wow, looks complicated, but thanks for the diy......been looking for one for a while
Old Jan 3, 2005
opto_isolator's Avatar
Its not easy - this is a job for someone who has done something like this in the past....
If you aren't comfortable without having your car for a day or 2, take it to a professional. It took me 2 days to install my clifford....
Old Jan 3, 2005
profuse007's Avatar
Senior Member
I broke it down into ttwo parts: 1. install the alarm/RS/keyless unit
2. install the 555I, antitheft bypass
the tutorial is planned out. read all the diagram, i marked all the wires you need and not need and maybe needed for installation. if you have ?, just ask.
whats good about this tutorial is that you can pretty much get any DEI products. theres like 10 diff type of units made by DEI that have an exact diagram.
Old Jan 3, 2005
profuse007's Avatar
Senior Member
it shouldnt be complicated, ive tested every wires and ensure the right connection. there are pics of the locations on where to get those wires in ur civic.
all y'all have to do is make connections.
Old Jan 3, 2005
armieo's Avatar
< My future wife.
Very helpful, thanks.
Old Jan 3, 2005
profuse007's Avatar
Senior Member
Clutch Bypass
plz do not ask me about tempoarily bypassing clutch when RS. the unit is made for automatic EFI.
i nor this site dont think either of us should encourage this kind of hazard...... just email if youre just so curious.
NEXT tutorial: ill try to write up a compustar 2wss-as for MTranny civics. this unit is safe for MT's.
Old Jan 3, 2005
profuse007's Avatar
Senior Member
the installation time is appx ~4hrs for average isntallers out there.
the installation time is appx ~1day for DIY (better start early in the morning)
what clifford model did you used?
Old Jan 3, 2005
Wolfgang5884's Avatar
nice, i'm getting my alarm soon
Old Jan 3, 2005
I have an intelliguard 850....
The hardest part is splicing in all of the wires, especially the ignition kill, since they are so large. Other than that, routing the wires is the second hardest thing.
Old Jan 3, 2005
profuse007's Avatar
Senior Member
ill install the exact unit on a buddy's 01 prelude tomorrow.
some of the wire is kinda hard to read. the ignition is the easiest place to splice through, all the honda and acura have worked on the past are very similar in guage size and insulation size.
you prolly didint open the steering wheel shroud like i did to access to top end of the harness.
Old Jan 18, 2005
_Viper_'s Avatar
Wow man looks hella tough wow
Thanks
alot
Old Jan 19, 2005
profuse007's Avatar
Senior Member
its all about find wires and connecting them together
here are some of the things you need to remember. these task takes practice and self torture when you first beginnin to install car alrm/RS this honda is quite simple compare to the others. as long as you read it several times and ask what you need to ask, anyone can DIY this.
Old Jan 19, 2005
R1Style's Avatar
can you clearify where exactly you would find each harness/wire?
Old Jan 19, 2005
HomerSimpson's Avatar
excellent work!
Old Jan 19, 2005
ALPHSTER's Avatar
THE FIRST LETTER!
ALPHSTER has disabled reputation
Had one installed on the wifes Highlander. They came to my job and installed it in the parking lot. It took about 3-4 hrs. Best investment ever! Now my wife and kid won't freeze anymore waiting for the car to warm up.
The damn thing can start the car 1000 ft. away. Good when you are at the mall. By the way you still have to insert the key in the ignition and unlock the car with the remote (car stays looked while warming up). If you forget you started the car it will shut down by itself in15 to 20 min. It will also shut down when you press on the brake if the key is not in the ignition in case some a$$hole tries to jack you $hit.
All and all pretty good stuff I hope you enjoy yours.
Old Jan 19, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i will see if i cant add this to the DIY sections...
Injen
Old Jul 20, 2013
verbstyler's Avatar
verbstyler is an unknown quantity at this point
Re: DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Any way we could revive that DIY link?
I need assistance in installing a Viper alarm on 01 Civic LX
Specifically how to wire up Unlock/Lock features of alarm
Thank you
Old Jun 18, 2014
CivicUnrest's Avatar
CivicUnrest is an unknown quantity at this point
It's probably too late, but here's a shadow copy without pictures...
https://web.archive.org/web/20130415...se007/id3.html
Old Aug 9, 2014
onedr's Avatar
onedr is an unknown quantity at this point
Fuhh. I never got around to seeing the original link but here's a diff DIY Viper install (w/ pics) that I just found half an hour ago. http://civic-eg.com/causeforalarm/em_civic/index.php
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
