How to get this part off? (intake install)
How do I get the bottom part of this box off? I took the screws out and took off the cover and filter and all the 10mm bolts I can find and it seems like there is still something holding it.
you just pull it up. Make sure you get all screws out though. They are all around it. It connects onto the throttle body so just pull it out. It might be a bit tough, be it should pop right out.
you can see that rubber blue piece where the intake meets the TB there is a clamp holding the tube on, but there is no clamp holding the whole intake to the throttle body, so I can pull it right off if I want... should I put a clamp there?
SneakerPimp
Bolt-on Engine Performance
Nov 4, 2001 01:12 PM
