Can a Civic be modified for drifting??
Rep Power: 271 Can a Civic be modified for drifting??
I know this may sound like a stupid question, but I've never really seen any Vics out there moded only for drifting.
I've already done some suspenssion mods on my car, but it still body rolls a lot on curves therefore I was wondering...
OMNES AD UNUM
Rep Power: 311 it depends on how you define "drift". their was a clip posted on this site where a civic hatchback (the 91 model -) doing a "drift" with e-brake in use. some ppl dont call it drift, some do. their was a argument over it too, try to search for it if its still in the archives.
Back From The Banned!
Rep Power: 315 just b/c a car has body roll doesnt mean it cant drift.... basically, the only techniques front drive cars can use tp drift are e-brake and possibly drop throttle oversteer.... but... thats about it... drifting is not for front drive cars..........
Rep Power: 271 ^^^Good point, but then WTF is my car body rolling so freaking much? I remember it didn't as much as it does now and the tires are used but still a lot of rubber to go so...
It oversteers a lot more now than before. I don't know, maybe once I put the Progress sway bars I could take turns better. I hope... What yall think??
Autocross Junky
Ignore the body roll. Handling wise it only does 2 things... 1. it annoys the driver and 2. it causes a bit of camber loss (which can hinder handling).
you say the car oversteers more then before... have you changed any thing recently? have you altered how you as a driver take corners? have you hit any bumps or Potholes that may have altered your alignment?
and just to be sure we are talking about the same thing,
Oversteer = when the rear end of the car starts to slide (Fishtail)
Understeer = When you turn the steering wheel and you still go in a straight line (Or are turning less then what the amount of steering imput should give you)
Rep Power: 271 Never thought of that...I forgot to mention that I did bring my camber to stock specs after I put the shocks & the camber kit. As far as suspenssion mods: Sporlines w/ HPs, camber kit & a Neuspeed USB. I should prolly take advantage of the alignment warranty and bring it to more negative, but then the freaking tires will start to wear out faster Damn it!! It's like every fvckin mod has pros and cons.
Rep Power: 271 Yeah Zzyzx...it's oversteering like crazy and I remember it wasn't like that before when camber was super negative. I haven't really driven it into potholes or stuff like that but I did bring the camber to almost factory specs as I mentioned above. I'm not even taking the turns faster...I mean it all really depends on the turns, but I'm refering to the same curves I drive through everyday. As far as changing something on the suspenssion, the shocks was the last thing I did, about 2 months ago....Crap, now I'm concerned about installing both sway bars.
Autocross Junky
Rep Power: 357 well Here's a couple of tips.
when the car start to over steer Don't lift off the gas or hit the brakes, as that will just make the oversteer worse. Instead add in a bit of throttle, you dont need to add much, just add some gas. and that should settle the car down some.
Also, Try to do more of your braking while you are going in a straight line, so that when you start to turn in, you should be coming off the brakes. If you are on the brakes while you initiate a turn you increase the chance of making the car oversteer.
Other wise, having a FWD car that oversteers isnt a bad thing... you just need to adjust the way you drive in order to take advantage of it.
Autocross Junky
Originally Posted by kasimmmmm
its impossible to drift with a front wheel drive unless you consider using the handbrake as drifting.
Funny, My car "Drifts" at just about every Autocross.... and all I have to do is lift off the throttle.
Addicted To Boost
Xuhme
21
08-07-2023 03:40 PM
cloudguy
04-28-2015 05:02 AM
GH04si
04-15-2015 08:13 PM
Cilvic
11-15-2001 04:54 PM
WeRkX
11-01-2001 10:33 PM
