RPM Signal wire?
Old Jan 10, 2005
HyaBoosta's Avatar
RPM Signal wire?
Hey Im installing my emanage in my civic and I have all the wires in but the RPM signal wire. I have the wiring schematics for my ecu and There is no rpm wire. What is the other name that they use for the wire that send the rpm signal? is it the crank position wire?
Old Jan 10, 2005
taz757's Avatar
Isn't that the tach signal? I dunno, maybe.
Old Jan 10, 2005
PunkingCivic's Avatar
I need TP for my bunghole
ask dezod he has one
Old Jan 10, 2005
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
solid Blue wire on the top plug on the ECU
Old Jan 10, 2005
djmota's Avatar
lets see if this pic works.
If not go to the vafc2 DIY and see the plug layout there.
Old Jan 10, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
if not go to my site (click on sig) and there another location for TACH signal, but its in the engine bay though.
look in TUTORIAL and scroll down.
Old Jan 11, 2005
HyaBoosta's Avatar
still not finding it?
Old Jan 11, 2005
realitycheck's Avatar
realitycheck is an unknown quantity at this point
I know its in the diy for the tach signal wire, because thats the one I tapped into for my tach I'll be looking also.
Old Jan 11, 2005
HyaBoosta's Avatar
BOOYA! It's called engine speed pulse. Connector E pin 26 blu wire. thanks for the help guys. The DIY fro the emenage is off a little.
Old Jan 11, 2005
dezod's Avatar
7thgen Power Maker
thanks Madwheel. LOL
Old Jan 11, 2005
HyaBoosta's Avatar
dezod do you have it hooked up to the connector A wire?
Old Jan 11, 2005
dezod's Avatar
7thgen Power Maker
I did the install of the E-Manage almost 6 months ago. I can't remember the exact wire.
But I would think..........
26-blu-Engine speed pulse
On connector E
Old Jan 11, 2005
abmerop18's Avatar
Jam out with your clam out.
did you figure it out? was it the connector e pin 26?
Old Jan 11, 2005
HyaBoosta's Avatar
^^ yeah I was going to IM you about that. It's con. E Pin 26. the blue wire.
Old Jan 11, 2005
dezod's Avatar
7thgen Power Maker
Soon enough you guys will be E-Manage gurus. Your on the path...
Old Jan 11, 2005
HyaBoosta's Avatar
^^You and madwheel are my idol's, I wanna be just like you when I grow up!
Old Jan 11, 2005
abmerop18's Avatar
ok cool. thanks for that hyaboosta. im gonna do that today and hopefully thursday when i get the support tool i ordered from SLP i will be installing my ignition harness and getting the e-manage all running good
Old Jan 11, 2005
dezod's Avatar
7thgen Power Maker
ROFL
I'll tell Madwheel you said that
Wild Cranker
May 19, 2015 06:10 PM
Fastfebur
Apr 22, 2015 01:37 PM
stpfrancois
Jan 19, 2002 08:53 PM
Diznavis
Jan 6, 2002 09:13 PM
blackbullet
Dec 1, 2001 03:44 PM
