tune up...
Some things I would suggest are sparkplugs, transmission oil flush/change, coolant flush/change.. brake pad/rotor change? I dunno.. I think someone else would have some better suggestions
I already dida tranny flush, pads are still good for now..
I'm pretty sure I gotta change the timing belt also,
what kind of plugs do you guys think i should get ?
well, i have 113 KM but thats bout 70 miles... and ya, i did check my manual. When they say change the brake fluid, where do I find the plug to flush it ?
NGK Iridium eh... is there a certin temp that I need them at ? My engine is bone stock.
NGK iridium IX stock replacements from sparkplugs.com
air filter
greased lightning fuel system cleaner
gas line antifreeze (do not combine with above)
4gauge ground wires to upgrade stock
brake fluid
tranny fluid
a/c service
cooling system service
oil change
timing belt (and crank pulley)
cabin filters
fuel filter
alignment
thermostat
compression check
and alot more.....
air filter
brake fluid
tranny fluid
a/c service
oil change
cabin filters
fuel filter
alignment
thermostat
compression check
and alot more.....
70k :P meep meep
Thx Gear !!! oh... and anyone have an answer to to flushing the brake fluid ?
air filter - Done already
greased lightning fuel system cleaner - I will pick some up
gas line antifreeze (do not combine with above) - there is antifreeze already added to canadian gas
4gauge ground wires to upgrade stock - I think I will go with 2g, stock grounds are all oxidizing
Good recommendation
brake fluid - how do you flush ?
tranny fluid - did 5k ago.
a/c service - I will leave it for the summer
cooling system service - ??????
oil change - done
timing belt (and crank pulley) - I will done
cabin filters - wait for summer
fuel filter - Ive read that its not really that important. Ive only used premium brand name fuels.
alignment - did 4 months ago w/suspension upgrades
thermostat - since i'm gonna do a rad flush, might as well...
compression check - DIY of course... just gonna rent the guage.
Thx for everything guys...
Good recommendationbrake fluid - how do you flush ?
oil change - done
You have to bleed the brake fluid from each wheel... I'm suppose to be writing a DIY on that I have picture but hey i'm lazy ..
Anyway the There is a Bleeder screw on The caliper in the front, and on the drums in the back you stick a small piece of clear vinyl hose on that and loosen that. someone pushes the brake down, tighten the screw while brake is depressed all the way. and keep repeating the process for each wheel, and always checking to make certain the brake resiovoir is full.
Originally Posted by AlienX
hehe, would you mind sending me some pics on how u are bleeding them..
I am lazy you know
Dawit Melese
Oct 4, 2015 08:02 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
