D17 is f***** up!
Old Dec 27, 2004
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
Angry D17 is f***** up!
As i found out today, and may come as a shocker to some of you. Our engines DO NOT HAVE AN OIL PAN GASKET. Techincally they do but our gasket isn't a normal gasket that you would see on a b16 or almost every other honda. We use, what is called, a double bond andhesive(which is a bitch to take off after it has dried and been on the vehicle for a while). Why am i saying this is f***** up? Because coincidentally i need to take of the oil pan. And because im a backyard mechanic with my primitive tools i can't do much but i bet that if our engines had normal gaskets i would be able to take it off.
Old Dec 27, 2004
taz757's Avatar
It's HondaBond. It's not that hard to break loose. Just get a large flat screwdriver and *gently* hammer it inbetween the motor and pan and it'll loosen right up.
Old Dec 27, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
New technology gotta love it.
Old Dec 27, 2004
Addicted To Boost
man i tried everything there is no way i can get in there with a scredriver
Old Dec 27, 2004
taz757's Avatar
Work at either right in the middle of the pan or on a corner. You've got to be gentle with it though, or you'll bend it.
Old Dec 27, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
there are tabs on the corners to pry it off with. it takes a little persuation but it does come off. Mine did. I just replaced the seal with gasket maker.
Old Dec 27, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
This method has been in use for a long, long, time. Anybody for a little RTV?
It shouldn't be too hard to peel loose.
Old Dec 27, 2004
civic01vtec's Avatar
hahahahaha.........u act as if u are working on a futuristic car. I took my pan off in 10 min......that includes loosening the bolts.
Crawl under the front of the car and near the tranny there is a tab........pry on that and pound the pan with a rubber mallet. Turn the wheels to the right and reach in through the wheel well and there is a tab there.......pry on that too.
Keep doing it till she comes loose. After it is off the motor........scrape off the excess honda bond and clean it up.........use some high temp RTV or get some more honda bond. I used Komatsu gasket maker which is like $15 a tube...........so far no leaks.
Old Dec 27, 2004
Civicious's Avatar
Civicious is an unknown quantity at this point
I had no problem getting mine off either. Then again I had my motor pulled. I took a Razor blade around the crack between block and the oil pan. Then I used a putty knife to pry and it popped right off.
Old Dec 27, 2004
Addicted To Boost
after fighting with it i succeded at taking it off. thanks guys
Old Dec 27, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
screw driver didn't work for me.... but try using a craw bar, or a chisel hammer or whatever they call it... normally hammers have that s l u t in the middle to pull out nails but this hammer i'm talkin about is just a pointed flat metal on the other side of the hammer that drives the nails...
when you slide underneath your car lookin at the front right corner of the oil pan has this extra metal piece sticking out, place the craw bar or the pointed part of the hammer their and yank it out, don't jerk it, it will fall on your face like it did to me i.e. big lump on the forehead and busted lip and oil all over my hair kinda accident... don't get lazy and drain oil prior to taking oil pan off
well good luck I hope I helped you out...
Old Dec 27, 2004
Balut Eating Champ
damn it! i'm late... oh well i'm in it for the .05
Old Dec 27, 2004
Mischieflts's Avatar
Mischieflts is an unknown quantity at this point
yea.... he got it out man.... rofl
Old Dec 27, 2004
streetglower's Avatar
just a question for all of you, when you removed your oil pan, did you have to remove the downpipe to get the pan off, or were you able to remove the pan without having to take off the downpipe?
Old Dec 27, 2004
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
If you've ever broken apart a differential, it's the same bs you have to deal with. Most diffs use that silicone stuff like a gasket.
Old Dec 27, 2004
yes, u will have to unbolt the downpipe and push it to the side.
Old Dec 27, 2004
_Viper_'s Avatar
Hey BTW I have an aluminum oil pan on my Si Sedan....Is it aluminum on non Vtec cars??????? also..
I remember that on escorts the GT had an aluminum pan and regular escorts had metal pans...
Im happy its aluminum then it doesnt rust out
yessssssssssssss
Old Dec 27, 2004
ummm.........what ???
It is exactly just the opposite
Old Dec 27, 2004
Addicted To Boost
I think he tried to say "Dont get lazy. Drain the oil before removing the pan"
Old Dec 27, 2004
opto_isolator's Avatar
LX has a gasket because it has a steel oil pan....EX has an AL oil pan, doesn't need a gasket, only hondabond.
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
lyanreindecker
Aug 20, 2015 09:15 PM
CivicLude
May 12, 2002 08:01 PM
bo0sT
Apr 3, 2002 09:11 PM
