Sponsored by:
Sponsored by: CARiD
Triple Pod Pillar
Old Dec 24, 2004
Michalo187's Avatar
Abortion Survivor
Triple Pod Pillar
I am thinking of getting the pillar but just for looks to add a little more show points but i actually want them to help me out so which gauges do you think i should i get? I was thinking Water Temp, Oil Pressure and Oil temp tell me what you guys think i need your help thanks.
Old Dec 24, 2004
Michalo187's Avatar
Abortion Survivor
Gauge 1: Oil Pressure Gauge
Gauge 2: Voltmeter Gauge
Gauge 3: Water Temperature Gauge
Those are the ones i want to get
Old Dec 24, 2004
onelonelydriver's Avatar
onelonelydriver is an unknown quantity at this point
I was thinking about get one of thsoe too, but i haven't yet. You should get what you think is worth your money and whatever you want. Good luck.
Old Dec 24, 2004
mexinaction's Avatar
i have been trying to find some myself for my 04, 01-03 dont fit the 04's very well
those are the same ones i am going to get, plus the boost one i get turbo
Old Dec 24, 2004
allmotor's Avatar
nor cal 7thgens
yeah those three gauges will work fine.
Old Dec 24, 2004
supermanrjs's Avatar
We pre-game harder than you party!
supermanrjs is a jewel in the roughsupermanrjs is a jewel in the roughsupermanrjs is a jewel in the roughsupermanrjs is a jewel in the rough
get air fuel ratio....those look bad at night........
Old Dec 24, 2004
C2i0v0i1C's Avatar
SuperMODrizd
get electrical, not mechanical, u dont want oil and hot water coming in the cabin
Old Dec 24, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
no need for oil temp, you got one on your dash already.
Old Dec 24, 2004
C2i0v0i1C's Avatar
SuperMODrizd
can u point that out to me, the only two things i have in mine, gas on the right and coolant temp on the left
Old Dec 24, 2004
Blahman2's Avatar
I thought the coolant temp was actually the oil temp. Anyone wish to clarify this?
Old Dec 24, 2004
Blahman2's Avatar
what exactly would you need a Water Temp, Oil Pressure,Oil temp, volt gauge for? Basically show? Seems to me the only useful gauge would be a boost gauge.
Old Dec 24, 2004
C2i0v0i1C's Avatar
SuperMODrizd
well fuel pressure, AF, boost, EGT, oil pressure is good with turbo, they serve a purpose
Old Dec 25, 2004
zachgeyer's Avatar
koolness
Old Dec 25, 2004
Michalo187's Avatar
Abortion Survivor
Like i said at the start they are basically all for show but i might as well get ones i can use
Old Dec 25, 2004
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
allmotor was right when he said Water Temp / Oil Pressure / Volt Gauge were the most useful...
Water Temp tells you if something has gone wrong in the coolant that is circulating thru your engine block (hose is leaking or blown off; water pump failure, etc.). When the gauge goes into the red, the block is overheating and you will have head gasket failure or worse the whole engine will fry.
Oil pressure tells you if the oil pump has stopped sending oil to the critical moving parts of your engine, and you know what that means. Oil pressure is so important that many drag/NASCAR cars don't even use a gauge--things happen so fast they use a giant red light to indicate oil pressure loss so the driver can shut down the engine ASAP to try to prevent damage to the engine.
Voltmeter is used to keep an eye on your alternator, which comes in handy if you have ICE. You can make sure the amps are getting the right voltage range. Even if you don't have ICE, it will tell you if the alternator is failing and your car is draining the battery.
Old Dec 25, 2004
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
here are the most sensible ones if u dont have a turbo:
1. Voltmeter - if u have a system, keep an eye on your battery levels
2. Air/Fuel Ratio - looks good at night, easy to hook up
3. Oil pressure - if u have VTEC, it jumps around when it kicks in
I have an 03 LX, and have a dual gauge pod with air/Fuel and a voltmeter, both as cool, but if I had VTEC I would have definitely got the triple pillar
Old Dec 25, 2004
Michalo187's Avatar
Abortion Survivor
Yeah thats true thats why i want them for sure and for some help in telling me things are wrong.
Old Dec 25, 2004
Blahman2's Avatar
What do you think of this gauge pod? http://www.importparts.com/shop/inde...bc77c02b2c8d8b
ZoSoIV
Sep 17, 2015 07:17 PM
RIPSAW
Aug 16, 2015 12:14 PM
2Hottie
21
Dec 27, 2003 04:56 AM
CIVICMAN67
Jun 16, 2002 12:55 AM
TypeR2k1Civic
Dec 15, 2001 10:10 AM
