Any recommendation on DIY Brake bleeding kits?
Old Dec 23, 2004
streetglower's Avatar
What does everyone recommend out there for a one man bleeding kit. I have seen so many off the internet, but which one would you recommend. Or what kits do you have?
Old Dec 23, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
just get speed bleeders
Old Dec 23, 2004
dariusld's Avatar
dariusld is an unknown quantity at this point
What size? There is no listing for our cars.
Old Dec 23, 2004
what the hell is that? Sorry, but I dont know much about brake bleeding. That is why I am trying to get as much info on kits as I can.
Old Dec 23, 2004
dariusld's Avatar
I found the answer in another post. SB1010 for the front. SB8125l for the rear. Speed Bleeders explained.
Old Dec 23, 2004
tavdawg's Avatar
tavdawg is an unknown quantity at this point
This is what we use at the garage... http://buy1.snapon.com/catalog/tools.asp?tool=all&Group_ID=1672&store=snapon-store They work very well.
Ok well go to the snap-on website and find the catalog and click on brake and you will see it.
Old Dec 23, 2004
Zzyzx's Avatar
Autocross Junky
Try this one..
http://www.gofastlab.com/s2ki/produc...&cat=48&page=1
Old Dec 24, 2004
the only thing I am worried about with speed bleeders or where you need 2 people to do it, is when you are actually bleeding each wheel, I am afraid the master cylinder will go dry really fast. Unless there is alot of fluid in there.
Old Dec 24, 2004
Pete W.'s Avatar
Pete W. is an unknown quantity at this point
You just need to keep a close eye it. The good thing with the speed bleeders is you crack them open pump pedel some, top off the cylinder.
If you over think it it would be I need to bleed the brakes, I need one person to keep fluid in the master cylinder, one to press the brakes. and one person to open and close the bleeder valve. Keep in mind every time I have bleed brakes I always have the person pumping the brakes man the fluid.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Youshoe
May 22, 2015 09:36 PM
BootyDo
May 7, 2015 04:46 PM
bsmiley
Apr 27, 2015 01:27 PM
