led install; fake alarm
Old Dec 22, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
aight so i was around a while ago looking at led threads through the search function, and found some diy for hooking up an led so that when the car is off the led blinks like having an alarm. as dumb as that sounds (similar to putting alarm stickers all over ur house windows) this should deter someone that is not a professional from brakeing in and stealing all my ish.
so i went out and bought some streetglow headlight led's to install one within the cabin. I searched for the thread again and nothing this time. Does anyone knoe how to set up the wiring for this (impulse? maybe).....need help and dont want to shell out 200-400 for an alarm that is going to do the same thing.
Old Dec 22, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Wiring is pretty simple. The LED should have 3 wires, one for the ground, one for the battery aka Constant 12V and one for the swich (usually connected to that core of the alarm)
The first two is pretty easy, Ground wire all you need to do is find some baremetal surface with a screw near by and by a screw hub and screw the ground wire in.
Battery aka constant you can splice into your fuses with this one all you need is a fuse splicer and a fuse tester. With the car turned off use the fuse tester to see which fuse still has constant power, then do the same with the car turned on.
The switch wire is similar to the battery aka constant wire. The only difference is you need to find a fuse that is not getting power while the car is turned on, other wise your led will be on all the time even when you are driving. To determine this use the fuse tester to see which fuse has no power while the car is one once you find that splice into it with the fuse splicer.
That is probally the easiest way with out cutting wires and such.
Old Dec 22, 2004
ArthurBrazil's Avatar
ArthurBrazil will become famous soon enoughArthurBrazil will become famous soon enough
do i smell a DIY
boy is that a good smell
Thanks MR Wong
Old Dec 22, 2004
2K1Civic17"Gabe's Avatar
My alarm light doesnt flash anymore?? I still have an alarm though, so somebody will think I dont have one, try to break in, and be like sh**! Does anybody know where to get some blue LEDs so I can replace it?
Old Dec 22, 2004
MrWong's Avatar
Bushido
You should check to see if your LED wire is still connected. No sense in buying another light if your current still works.
Old Dec 22, 2004
It is, but I would rather a blue one, or a blue cover for the light. I have a white light with a little red cover. I messed with it a bunch when I was trying to wire 2 isntead of one, but couldnt figure it out. Now it doesnt work, but is connected correctly.
Old Dec 22, 2004
MrWong's Avatar
Bushido
Well in that case you should look at some Varad LEDs, those are pretty bright.
Install process is the same as any other LED.
Old Dec 22, 2004
shouldnt take long at all to replace, just need some new ones. Thanks a lot, Ill go check those out right now!
Old Dec 22, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
radio shack sells them.. they are like a dollar for two..
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
