valve seal change
Old Dec 21, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
valve seal change
Can anyone tell me how to change the valve seals. I have a compression leak in my #3 cyl and it is steady wet and dry tested so it is not the rings. Also my valve it tapping cause I detonated in that cyl. Some one help.
Old Dec 21, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
You sure its the valve seals? Do a leakdown test and you'll be able to tell for sure before you rip into the valvetrain, it'll save you some time.
Old Dec 21, 2004
CrewChief's Avatar
leakdown test what the cyl? did the compression test on it wet and dry and it was the same. if it was the rings it would have been different wet to dry. And I know the head gasket is good I just changed it a little while back.
Old Dec 21, 2004
A leakdown test will allow you to pinpoint where the leak is by listening for escaping air, and comparing how much leakage there actually is. It screws into the spark plug hole just like a compression tester. You then hook it up to an air compressor and go from there.
Old Dec 21, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
yup.. what 4drcivic2k1 said... if the numbers are not correct you will know for sure
Old Dec 22, 2004
streetglower's Avatar
just cause you changed a head gasket awhile back doesnt mean it is still good. You cant make guesses on stuff, you have to investigate. You could put a brand new part in one day and it will go bad the next day.
Old Dec 22, 2004
CrewChief's Avatar
I did a pressure check on the coolant system and it checked good. no smoke. really rich smell comming from the exhaust though. no oil in the cyl. no abnormal pressure from the crank case breather but exesive oil and pressure comming out of the valve cover breather. Have to pull off the valve cover today and look for a bad valve spring or bent valve. #3 exaust valve is tapping. I'll do the leakdown also to make sure. Thanks. no help on how to change the seals though.
Old Dec 22, 2004
Most parts stores will have a leakdown tester to borrow or buy, if not I know where to find one.
I can also help you change the valve seals if that is determined to be the problem.
LionSpratt
Jan 29, 2017 11:07 PM
Supramk3
May 11, 2015 07:55 PM
leon1
Apr 28, 2015 07:32 PM
jstotts
Apr 20, 2015 09:32 PM
Grey
16
Jan 27, 2002 11:34 PM
