Sponsored by:
Sponsored by: CARiD
Revo problems??....
Old Dec 18, 2004
02civic_rida's Avatar
Revo problems??....
Ok.... There is a bolt that the shifter pivits on and it comes out and makes it so there is a lot of play in every gear, plus after it gets real loose, when i go to either 5th or Reverse and then try to go back to first it clicks.... the spring comes out of place and then goes back into the lil crease that it has for it, and thats what makes it click..... IF i take off the center console and push the bolt back in, it works find.... anyone else experiencing this??? please let me konw... i hate this.....
Old Dec 18, 2004
N E ONe!!!????
Old Dec 18, 2004
CivicRocker02's Avatar
I usually put a cucumber in my bum when I jerk off!
CivicRocker02 is an unknown quantity at this point
be patient its the middle of saturday people are out and about but no i havent experineced any problems w/ my revo ss.
Old Dec 18, 2004
gh0st's Avatar
TAQUITOS!!!!
i don't follow what you're explaining...what bolt are you talking about?
Old Dec 18, 2004
jakejham's Avatar
jakejham should not be trustedjakejham should not be trusted
uh, im hungry?
Old Dec 18, 2004
Toaster's Avatar
Toaster is on a distinguished road
Had the same problem the revo bolt has a flat side on it. I ended up replacing it with the stock bolt because it does not have the flat side. You could try and turn the bolt a bit so the flat side was away from the lit piece of plastic that hold it but it might just move back around.
Old Dec 19, 2004
^^ hum... good lookin out... i'll try that. when i have time to look at it durring day light... i'll look at it...
here is the revo
see those two bolts..... the one on the botom right is the one that starts comming out and then makes it so there is a lot of play in every gear, and when i push it back in its fine, but this is frustrating, because i have to do it like once a day or every other day...... I just got this thing not to long ago, i ordered it from truehonda, n e other pointers?
Old Dec 19, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
deleted post
Old Dec 19, 2004
Dishwasher's Avatar
Supertastic Member.
Dishwasher is an unknown quantity at this point
i used a file to eliminate that spring clicking sound, just round off the corner that it rubs against, worked pretty well.
supra8311
Sep 16, 2015 02:07 PM
dosmastr
May 5, 2015 12:19 PM
02CarbonCivic
Oct 6, 2005 01:03 AM
01civicboi
Nov 23, 2001 03:02 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
