Is there a HID DIY thread?
Old Dec 13, 2004
tamazoid's Avatar
tamazoid is an unknown quantity at this point
Hi! I was wondering if there's a DIY for install HIDs in a 2001 civic coupe in the oem housing? Pics would be great... I can't seem to find the thing I'm looking for!(I've search BTW)
Thank you!
Old Dec 13, 2004
ImPulse's Avatar
post pics of the kit and wiring
Old Dec 13, 2004
streetglower's Avatar
They arent that hard to install. You just hook up the wiring to the ballast and then to the headlight connecter.
Old Dec 14, 2004
tamazoid's Avatar
Hooking the kit up is easy... But how do you get the bulb to stay in the headlight and have the plastic cover on? I have a 2001 Coupe, and the metal picece that holds the bulb in gets in the way of the wires... I know the metal piece on the Sedan is different and is half like a hook... Is there a way I can unhook it on the Coupe or something? Then put the bulb in?
Sorry if you guys don't know what I'm talking about... Thanks!
Old Dec 14, 2004
wonderz's Avatar
wonderz is on a distinguished road
if you got the right size bulb.. which i assume u got stock headlight... then you should have a HID bulb with a H4 base.. you just change the bulbs like you normally would with stock bulbs... it should hook back up the same as stock... as for the plastic cover, u can either "customize" the cover so it would fit or just use some electrical tape to cover the back.
Old Dec 14, 2004
tamazoid's Avatar
Yes I got the stock headlights with the H4 base... The HID bulb fits in the headlight, but the metal locking thing that secures the bulb in place hits the wires... So there's no way I can get the bulb to lock up in place...
Old Dec 14, 2004
yurcov's Avatar
New Member
yurcov is an unknown quantity at this point
looks so strange, hit a few shots in here, it would be helpful
Old Dec 14, 2004
tamazoid's Avatar
Ok, here's the pic... I don't have a pic of my headlight because it's on my car and it's too hard to get a pic of. But this is a Sedan headlight... The metal piece that I'm talking about is highlighted in Red. But on the Coupe, it's a different metal picece that holds the bulb in... There's no way I can get around it without hitting the wires when I install the HID bulbs...
Old Dec 15, 2004
yurcov's Avatar
New Member
well, sound is really strange.I have coupe and the headlights are different, but any way, what I can suggest is drill a small hole in the housing and everything will be ok.
Otherwise could you shot pics of the HID bulb with wires go to the ballast and take your H4 bulbs out of the housing and lemme see whats worng.
Old Dec 15, 2004
tamazoid's Avatar
Yes I know the coupe headlights are different because I said I have a coupe headlight too, but the headlights I'm showing are the sedan headlights... I didn't feel like taking my coupe headlights out...
All I'm saying now is there's no way I can get around the metal clip(the clip that holds the bulb in) with the wires from the HID bulbs...
So my question is, how do you get the HID bulbs to stay in place in a 2001 coupe headlight?
Can I just unhook the clip and hook it back after to hold the bulbs in?
Now this is the best I can explain my situation...
Thank you!
Old Dec 16, 2004
yurcov's Avatar
New Member
if you got the right H4 HID bulbs as I assume you shouldnt have any problem with any wires go out from the rebased HID bulb. The coupe has a metal clip holding the bulb in and it will allow you quite easy to use any rebased H4 HID bulb.If you bulb doesnt fit into the housing, it means youve got the wrong bulbs, period. Shot a pic of you HID bulb, I`ll see it
Old Dec 16, 2004
gh0st's Avatar
TAQUITOS!!!!
^^^ yeah.
unless they rebased it weird and let all the wires go all over the place
Old Dec 17, 2004
tamazoid's Avatar
There's nothing wrong with the fitting of the bulb into the housing... I just can't close it cause it will close on the wires... I can't just can't unhook the wires from the bulb...
Actually, nevermind... I'll figure something out... Thanks.
Old Dec 17, 2004
88d15HB's Avatar
88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted88d15HB should not be trusted
uheard ?
manfredww1
Jul 14, 2015 10:24 AM
manfredww1
Jul 12, 2015 07:31 PM
Jul 12, 2015 11:54 AM
