DIY: Magnaflow exhaust install
Old Dec 15, 2001
ayzan's Avatar
ayzan is an unknown quantity at this point
DIY Magnaflow exhaust install
For those who did the group buy on the Magnaflow exhuast, here is the DIY I told everyone I would do.
Keep in mind, my install was on a EX coupe. If you have an LX, HX, or DX, you will not use the flange but instead, use the flanged pipe to bolt up to the catalytic converter in the front of the engine.
Remember this is a Do It Yourself and I or this website are not responsible for what you do! Please take every safety precaution when working under a car and use proper safety equipment.
The file is in MS word format.
DIY Exhaust download
Old Dec 15, 2001
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
good one.
Old Dec 16, 2001
Maximus's Avatar
Maximus is an unknown quantity at this point
Nice.........to you and everyone else who takes the time for DIYs, much appreciated!!
Old Dec 16, 2001
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Pretty awesome set-up huh? I love mine!
Old Dec 16, 2001
uicmedruss's Avatar
uicmedruss is an unknown quantity at this point
Hey man...thanks for the DIY! Hope it becomes a habit for people to post really complete ones like that!
Old Dec 16, 2001
CapYoda's Avatar
Escaped Convict
thats good detailed one dude. good job.
Old Dec 19, 2001
DRS's Avatar
DRS
DRS is an unknown quantity at this point
good DIY guide. How do you like you exhaust?
Old Dec 20, 2001
ayzan's Avatar
I like it, the piping is a little low, but I fixed that by adjusting the piping and clamps. It's not loud, it's actually quiet after 4000 rpms. The packing is loosening up a little so it's starting to get a little deeper in tone. Very good for 300 bucks.
Old Dec 20, 2001
SQCivic's Avatar
SQCivic is an unknown quantity at this point
Hey ayzan - What adjustments did you make? Thanks
Old Dec 20, 2001
ayzan's Avatar
I rotated the pipe to the right which raised the catalytic converter. That solved that problem. I took the rubber mount off the resonator and put it through the center which raised the pipe a little closer. Because the diameter of the mount is bigger, I bought a hanger from kragen and used it hold the mount in place. I took off the heat shield from under the pipe which gave me enough room to rotate the clamp side ways. The clearance problem is with the clamps, not the pipe. I now can clear speed bumps up to 4 inches in height without angling the car side ways. Keep in mind my car is lowered 2.25 inches.
But even if you scrape, it's only the clamps. You can buy the same exact clamps at kragen or pepboys for $2.48. All my Hondas and Acuras were low to the point were scraping was a normal thing. You get use to it and then you'll learn your scrape points so you'll know how to go over speed bumps appropriatly.
Old Dec 20, 2001
bobbyd's Avatar
Just so you know, that is not the catalytic converter that you raised, it is the resonator. This system kicks butt!! I am glad you said yours was a little low cause I thought it was just me. Mine is a little lower but you can't see it or anything.
Old Dec 20, 2001
ayzan's Avatar
No, my converter was a little low....but it was because of the piping. When I rotated the pipe a little more to the right, it raised the catalytic converter but lowered the rear section of the pipe near the resonator. I raised the resonator by raising the rubber mount and putting the hanger through the center. Since the diameter is bigger, I used a tie down to hold it in place.
I stand correct.
Old Dec 21, 2001
SQCivic's Avatar
I didn't realize you were lowered. Just a stock Civic would probably not have much of a problem.
Old Dec 21, 2001
bobbyd's Avatar
Sorry dude. I thought that you thought that the first resanator befor the muffler was the cat.
Old Dec 21, 2001
ayzan's Avatar
SQCivic, if you are not lowered, you will have no problem with clearance.
Old Dec 24, 2001
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
great job on the diy
Old Dec 26, 2001
pinoycivicdxb's Avatar
pinoycivicdxb is an unknown quantity at this point
good and neat job keep all the DIY comming [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 26, 2001
RSXtypeIvtec's Avatar
Su Mo
anyone have a sound clip on this?
Old Dec 28, 2001
vino's Avatar
vino is an unknown quantity at this point
yah any clips???......thinkin of purchasing one.....i think its the cheapest exhaust in parts....
Old Jan 4, 2002
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
dang..how much was the exhaust for the group buy ??
Old Jan 4, 2002
bobbyd's Avatar
was $300 shipped! Awesome price.
Old Jan 6, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
it will be better for u just do a custom exhaust !!!
Old Apr 17, 2002
PlatnumBomb's Avatar
PlatnumBomb is an unknown quantity at this point
mine sounds great and all..but I'm gettin vibrations when I first acclerate in first...and sometimes when I corner...WTF???...It doens't seem like anything is loose...I dunno what is up with it???
suggestions???
Old Apr 17, 2002
Bryn's Avatar
Bryn is an unknown quantity at this point
Sound clips??? Any one have one??? I'm really interested to hear the sound. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 17, 2002
bobbyd's Avatar
Someone posted sound clips before in another post.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Reverb2005
Jun 26, 2015 06:22 PM
Red_Chaos1
Jun 21, 2015 01:12 AM
bsmiley
Apr 27, 2015 01:27 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
