Cheap Mods for Hp Gains
Old Nov 26, 2004
CivicEXofD0om's Avatar
CivicEXofD0om is an unknown quantity at this point
Exclamation Cheap Mods for Hp Gains
Hi my name is justin. I just got a 94 Civic EX 2dr Coupe. I got the 5speed SOHC 1.6L VTec. Im just wondering if you guys could tell me what i can do to my car for hp gains but with out killing my wallet. I already have a short ram intake.
Thanks from da woods in Wisconsin
Old Nov 26, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
D16Y...... hmmm...... headers......
basically, modding is expensive...... I wouldnt recommend someone not have lunch for a week just to get cam gears or something (just an example)
Old Nov 26, 2004
C2i0v0i1C's Avatar
SuperMODrizd
ditch the header, and the short ram, get the edlebrach (SP) turbo kit
Old Nov 27, 2004
If i could afford the turbo kit i wouldnt be asking for inexpensive mods
Old Nov 27, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
after you purchase an aftermarket header, you can go with a straight pipe from header all the way to muffler.. i think that goes for about $150-$250? thats without muffler. muffler would be about $10 for ebay cheap **** or $100 quality apexi n1 or something else. if you dont have smog emissions in your area, i'd definately go for it. but keep in mind, your car would be crazy so i suggest choosing a low profile quiet muffler. even with a quiet muffler, car will still make a lot of noise.
if your doing et's and dragging, should look into lighter wheels and grippy tires.
Old Nov 27, 2004
bakablo's Avatar
bakablo is an unknown quantity at this point
theres no such thing as cheap mods for hp gains.. if u want hp.. be ready to spend some cash
Old Nov 27, 2004
SLO REX's Avatar
250+ awhp Stage 2
So true.
Old Nov 27, 2004
import2nr's Avatar
awd pwnz j00
w3rd ^^
Old Nov 27, 2004
import2nr's Avatar
awd pwnz j00
just curious, whyd you join 7thgen if u have a 5thgen ?
haha just wondering
Old Nov 28, 2004
cuz its a honda site and id figure i could get some pointers
Old Nov 28, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
www.honda-tech.com
Old Nov 28, 2004
weight reduction, intake, jet coated header, pullies (not crank pulley), ground wires, hyper voltage system.
Old Nov 28, 2004
D17thgen's Avatar
also try www.clubcivic.com
see what kind of times and hp gains their getting with the same model civic as yours. only 7thgen and few rsx owners on this site. prob 1 s2k and 350z owner and other random cars.
Old Nov 28, 2004
wonderz's Avatar
wonderz is on a distinguished road
random cars are mostly made up of owners that have/had a 7thgen
Old Nov 28, 2004
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Nitrous
Old Nov 28, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
Yup. Nitrous or a used turbo kit. Cheapest HP per dollar spent. 200 intake with 5whp = $40 per whp.
50 shot nitrous kit for about 800 = ~40whp per whp.
Old Nov 30, 2004
ArtIntown11's Avatar
The Original F*ckin Angry Armenian
ArtIntown11 has a little shameless behaviour in the past
listen you dont buy a honda to go Fast for Cheap, you buy a honda if you want reliability, if your dont wanna use a lot gas, want a good bang for the buck, are a ricer, or wanna spend a lot of money having fun in a car that wasnt meant to be a fast sports car. In short your not gonna do much without boosting or swapping or Nitrous so there are your options. Sorry to be an ******* but plain and simple a honda is not a chevy small block where you will see huge gains. You dont have much options man and whoever told you, you did doesnt know what they are talking about. 1 word for you. BOOST
Old Nov 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
u didnt specify anything at all
Old Dec 21, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
if you haven't already done so lower it I put after market springs on my 04, put at least a front strut bar, I think you can get a whole set front back and lower on e-bay for under $50.00 I had to run a Neuspeed on my 04 because of that cold air intake.
your car should be fast enough, if you really want to go fast ditch the civic, and buy a Z or something. those suspension mods will make the car handle much better.
Engine wise you could have your head ported and polished, and maybe go with higher lift cams, but that is expensive, and complicated.
Old Dec 21, 2004
ArthurBrazil's Avatar
ArthurBrazil will become famous soon enoughArthurBrazil will become famous soon enough
buy a nitrous kit blower and a short ram
ok ditch the first to
Old Dec 21, 2004
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
CHEAP MODZ FOR MOST HP GAINS
El Cheapo Mod #1)
Nylon Panty hose Intake.
a.) Take of your stock airbox.
b.) Zip tie at least two layers of panty hose to the intake port
c.) Ignore the "check engine" light.
Cost $5, HP Gains at least 10
El Cheapo Mod #2)
Hack saw the Catalytic Converter
a.) Take a hack saw and climb under your car.
b.) Hack the Cat off, before and after.
c.) Find a Scap piece of pipe the approximate length of the cat.
d.) Use plenty of High Heat Duct tape to connect the new Pipe.
e1.) Drill at least 8 1" holes in the bottom of the stock muffler.
-or-
e2.) Hack the muffler off
Cost $7 (Pipe is expensive), HP Gains at least 10
So there you have it.... 20 HP for $12... That 1.67Hp/$
Good Times man... Good Times
Legal disclaimer
El Cheapo Modz, INC. Does not make any claims to the legality or unassailability of the said modifications. Nor does El Cheapo Modz, INC. warranty any modifications that you may perform from spontanous combustion.
Old Dec 21, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
I got the El Cheapo Mods #2 kit on my old accord. It was definitely worth at least 10 hp.
Old Dec 21, 2004
scatman's Avatar
Still in the game...
type r stickers
altazza tail lights
a raspy exhaust with a 5in tip
chrome hub caps
o, and dont forget a huge *** wing to keep that monster pushed onto the ground when ur racing down the highway at 90
Old Dec 21, 2004
4jacks's Avatar
Originally Posted by Scatman
type r stickers
altazza tail lights
chrome hub caps
These modz are not to be confuse with El Cheapo Modz INC.'s high quality performance developed modz.
Those modz are from our rival corporation El Ghetro Modz INC.
Old Dec 21, 2004
scatman's Avatar
^^bahaha
Old Dec 21, 2004
SLO REX's Avatar
250+ awhp Stage 2
LMAO that is damn hilarious.
Old Dec 30, 2004
allmotor's Avatar
nor cal 7thgens
make ur car lighter/ i/h/e 50 shot
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Zygrene
Mar 22, 2016 12:36 PM
pilebuck13
Sep 21, 2015 10:45 PM
