Could you wire your high and low beams together?
Old Nov 23, 2004
civic2uner's Avatar
This is just an idea... but do yall know how if you pull you light lever back half way between dim and how you flash your lights at someone, then both your highs and lows are shining? is there a way you could wire them together so that when you put your lights on bright it would shine both beams?
Old Nov 23, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Yes there is a way.
Old Nov 23, 2004
civic2uner's Avatar
do you think it would make your bulbs burn out quicker?
Old Nov 23, 2004
That function is only for short term use to flash someone. If you have both filaments on, the bulb life will drop drastically.
Old Nov 30, 2004
pyrofoam's Avatar
Love doesn't exist, only blood.
pyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trustedpyrofoam should not be trusted
i have been able to balance the low / high, yu can practise, and its easy to just push it forward enuff to do it. i did it, and i stopped, cuz my left bulb burnt out after a few weeks, so, it does wear em out alot faster.
but, its brighter!
stryder12
Jun 30, 2015 08:33 PM
jbander
Jun 4, 2015 05:56 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Hondasport01
Lighting
Jul 12, 2005 07:45 AM
CiViCsIkNeSs
Jan 7, 2002 12:16 AM
