Bumper not flush with fenders
Old Nov 23, 2004
TrboEM2's Avatar
Member
TrboEM2 is an unknown quantity at this point
i just reinstalled my oem front bumper this weekend after blacking out my headlights and i cannot get it to sit flush with the fenders. it sags about 1/4" below the flush point. i just ahve those black snap plug things holding it and the screwes that hold it to the fender. i do not have any more of the snap things that attach to the bumper anymore cause i lost them. is that the problem? and if so, how much would that cost to repair if i took the car to honda to get fixed?
side not, anyone know what the stock warrenty is, 30k or 33k miles? i might need to head in to get some things fixed before i run out of time.
Old Nov 23, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
3 years/36k which ever comes first.
Old Nov 23, 2004
TrboEM2's Avatar
Member
ok. thanks. do you think this would be covered under warrenty?
Old Nov 23, 2004
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
just go to honda and get the clips that you are missing, they are cheap and in stock.
Old Nov 23, 2004
TrboEM2's Avatar
Member
is that the problem then? how much do those run usually and how many do i need?
Old Nov 23, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
those clips are NOT cheat.. $4.80 EACH
i broke every one cept for the 4 that were on top of the grille... gutta remember.. "pry... dont twist".. woops..
anyway they are way cheaper through hondaautomotiveparts.com
put as many cllips as you can on the top part (over yer grille) and use zip ties for the rest of it.. the brush gaurd thing will make some serious noise if yer doin 80 down the highway with its only attached in one or two places..
as far as yer bumper being off.. sound like you are clicking it in under the slots on the fender.. try remounting it again.. i screwed it up the first time i took mine off
Old Nov 23, 2004
You need to align the tabs on the bumper with those directly under each headlight. It's hard to get them all in, but that would explain why it sags. Mine does a bit too. Just take off the bumper and look right under the headlight. Everything has to line up.
Old Nov 23, 2004
TrboEM2's Avatar
Member
do i need those clips or do i just need to reinstall it?
Old Nov 23, 2004
I would get the clips too just to make sure it doesn't fall off when you're driving.
Old Nov 23, 2004
TrboEM2's Avatar
Member
it is not the black push in snaps i am missing, just the little things that go on the bumper and snap onto the car i think. would it still sit flush without those, cause that is all i want now.
Old Nov 24, 2004
againifall's Avatar
Go Team Venture!
http://www.hondaautomotiveparts.com/...catdisplay.jsp
what year are we talkin about?
Old Nov 25, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
my gas door (left side edge) isnt flush w/ my body panel
Old Nov 25, 2004
TrboEM2's Avatar
Member
honda is gay. they wanted $40 + tax to fix it. screw that
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
Sep 27, 2015 11:33 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
rnaodm
Sep 21, 2015 12:42 PM
